Question 24V with MM board
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by James Robbie, Nov 23, 2018.
  1. James Robbie
    James Robbie Active Member
    IT Specialist
    New Zealand
    538Coins
    Hi all,
    I am looking at adjusting my setup and I’m looking at motor options. Currently I have a 2DOF arduino MM (single MM board) setup using 2 x wiper motors.
    One option I have is going to some 24V motors. Can I run 2 x 24V motors off a single MM board? I’ve seen some data sheets where it says max voltage is 16V so I’m guessing it would be frowned apon.
    Do people run 24V motors through MM boards at all?
    I don’t have the coin at the moment to go out and buy new boards like the JRK :( :( :(
    Thanks in advance
    150,578Coins
    +11,017 / 55 / -2
    You would be better off with a sabertooth for 24v, MMs are not suitable.
  3. James Robbie
    IT Specialist
    New Zealand
    538Coins
    Haha I was going to message you directly @noorbeast but I didn’t want to be a pest. Thanks for that
  4. ferslash
    ferslash Active Member
    4,798Coins
  5. micma80
    micma80 Member
    548Coins
    Hi, you can try this on bay (5-7€. 43A & 45 V)
    DOUBLE BTS7960B DC 43A Stepper Motor Driver H-Bridge PWM
    regards
    micma
