Question 24v DC motor
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Jakob Carron, Mar 12, 2019.
  1. Jakob Carron
    Jakob Carron Member
    34Coins
    Hi I have 2 24v Dc motors, and a 12v power supply. The motor will not spin, is it because of the voltage of the power supply or is it something else? Also if it is the power supply if I get another 12v power supply and connect them in a series. The motor is
    uxcell DC36V 80W 40RPM 6N.M Reversible Worm Gear Motor High Torque Speed Reducing Electric Gearbox Motor-JCF63R
  2. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    Si el motor es de 24vdc, la fuente de alimentación debe ser de 24vdc, si tiene uno de 12vdc, puede comprar otro y conectarlos en serie para obtener el 24vdc, debe tener en cuenta la potencia que las fuentes son óptimas para los motores.
    150,776Coins
    +11,021 / 55 / -2
  4. zapata_h
    España
    308Coins
    Sorry it was an error to have the page translated with google
