Question 2 DOF DC MOTOR ANALYSIS
Discussion in 'DIY Motion Simulator Projects' started by khairul, Jun 7, 2021.
  1. khairul
    khairul New Member
    155Coins
    2DOF, 3DOF
    hi everyone, any of you had done some analysis with SMC3 or 2 DOF motion simulation?
    - Question?
    1. what you analyze from this project?
    2. what tools or software you using to analyze?
    3. How to monitor PWM when we run LFS or any game?
    Thanks you for helping me. I only can monitor PWM using SMC3 and can analyze this signal.
    Any idea or example that i can follow? very appreciate your idea and example
    153,143Coins
    +11,117 / 56 / -2
    I am not sure I understand your question, but it seems to be how to run SMC3 and SimTools at the same time, so you can see the SMC3 output whe running a game and if so the short answer is you can't, as it would cause a port conflict.
    The purpose of the SMC3 visualisation is to assist in setting up the PID related parameters, once that is correctly done the settings are saved and no further tweaking is required.
  3. khairul
    khairul New Member
    155Coins
    2DOF, 3DOF
    any another alternative i can use to monitor this waveform? cause i need to do some analysis for my project.
    153,143Coins
    +11,117 / 56 / -2
  5. Bontekop
    Bontekop New Member
    Mechanical Engineer
    Hasselt, Netherlands
    107Coins
    If you want to monitor the PWM signal, maybe you can hook up a logic analyzer.
  6. khairul
    khairul New Member
    155Coins
    2DOF, 3DOF
    that great. thanks for sharing
