180 degree hall effect potentiometers
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Richardamo1, Apr 20, 2023.
  1. Richardamo1
    Richardamo1 Member
    307Coins
    2DOF, DC motor, Arduino, JRK, Motion platform
    Hi guys
    Looking at doing some setup and testing on a mock up board this weekend.
    Was looking for any info on setup for hall effect pots and the arduino uno board,do they wire up to the original pins as per 10 k pots or is there a completely different procedure.
    Any help ss usual would be much appreciated
    150,692Coins
    +11,018 / 55 / -2
    You should be able to treat Hall sensors as drop in replacements for post, with the benefit of direct connection, nit breaking if over rotated, great resolution and long life span. Just make sure you have polarity correct.
  3. Richardamo1
    Richardamo1 Member
    307Coins
  4. Richardamo1
    Richardamo1 Member
    307Coins
    As always
    Thanks for the speedy reply
    Will post some pics of progress this weekend,now have laser cut motor mounts and control arms,so basically ready to mock up this weekend
