Гидроцилиндр для сим совместимый с ардуино
Discussion in 'New users start here - FAQ' started by Vitaliy_Tambov, Feb 10, 2016.
  1. Vitaliy_Tambov
    Vitaliy_Tambov New Member
    Russia Tambov
    293Coins
    Доброго времени суток уважаемые форумчане!
    Как вариант рассматриваю построить сим на гидроцилиндрах, приблизительный вес сима 700-900кг я так понял: Гидронасос---пропорциональный клапан с драйвером--сервогидроцилиндр с датчиком. Помогите понять стоит ли рассматривать гидравлику для сима.
    150,728Coins
    +11,018 / 55 / -2
    Google Translate -
    Gidrocilindr for sim compatible with Arduino
    Good day dear friends! Alternatively, consider build sim on cylinders, the approximate weight of 700-900kg Sim I understand: --- hydraulic pump proportional valve driver - servogidrotsilindr with the sensor. Help to understand whether it is necessary to consider the hydraulics for the sim.
    By all means post in your native language but please do also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
    It would be helpful if you provided a basic plan of what you want to build and links to the specification of components such as hydraulic actuators so members have an idea of what you have in mind.
  3. Historiker
    Michigan USA
    9,208Coins
    And moved to the correct forum section.
    Welcome to XSimulator.net @Vitaliy_Tambov
