GTA5 Plugin Help ? pleeeease :)
Discussion in 'SimTools Plugins' started by SilentChill, Feb 2, 2016.
  1. SilentChill
    20,601Coins
    Hi folks,
    I'm really struggling trying to make a plugin. I have all the information I need (I think) however I have no idea how to do it since I can't code :(
    I might be totally wrong with this anyways but maybe you guys can say if it can be done or not i'm sure it can someway as Force Dynamics have it working @value1 @yobuddy @prilad
    There is a mod you can add to GTA5 called ScriptHook5.NET so that you can pretty much modify anything and call up data that you need. Here is the post over at http://gtaforums.com/topic/789907-vrel-community-script-hook-v-net
    Community Script Hook V .NET
    You may remember the .NET ScriptHook back from GTAIV, it allowed using the easy to learn, but extremly powerful .NET languages to write scripts that can be executed ingame.
    About
    This ASI plugin for the just released Script Hook V attempts to recreate this experience for GTAV. It's full source code is hosted on Github, development is community-driven and open to everybody, so contributions are warmly welcomed.
    Right now it's able to load, compile and run .NET scripts and reload them while the game is running (press the "Insert" key). It also comes with a vast scripting API abstracting away the native function calls (you can still do those manually through "GTA.Native.Function.Call" though). Scripts are executed in a separate AppDomain, any exceptions thrown thus shouldn't affect the game or ScriptHook.
    Thanks a lot to Alexander Blade for Script Hook V and HazardX for the inspiration with his GTAIV .NET ScriptHook.
    Download Latest Binary Release
    Installation
    1. Install both the Microsoft .NET Framework 4.5.2 and the Visual C++ Redistributable Package for Visual Studio 2013 (x64) (or loading will fail).
    2. Download and install the latest Script Hook V (including the ASI loader).
    3. Download Community Script Hook V .NET and copy the ASI file into your game folder.
    4. Create (or download) a C#/VisualBasic code file (.cs, .vb) or compiled .NET assembly (.dll) inside the "scripts" folder in your game directory and start scripting!
    Contributing
    Important files:
    • source/core/Main.cpp: The main script entry point
    • source/core/ScriptDomain.cpp: .NET script manager. Loads, compiles and executes the scripts.
    • source/core/Script.hpp: Class from which all scripts have to inherit, handles the script main loop.
    • source/core/Native.cpp: Managed to native function call conversion.
    • source/core/NativeHashes.hpp: Native function hash enumeration.
    The remaining files in source/scripting implement the scripting API. Any help on improving that API is much appreciated.
    Documentation
    Either use notepad to edit source code scripts directly or use Visual Studio to compile them to assemblies. Going down the Visual Studio way has the advantage of syntax highlighting, code completion and Intellisense (since there is no API documentation yet). Just create a C# or VisualBasic class library project, add a reference to Script Hook V .NET (rename the ASI to DLL) in the project properties and you are ready to go.
    If something doesn't work, check the log file. It catches exceptions and gives you all the information to get to the bottom of the problem.
    Now here below are the commands you can use in a script to get what you want and what I was thinking is that some of these could be exported somehow and used in simtools .
    Am I barking up the wrong tree here or do you think this is doable ?
    Thanks in advance for your input if you have any :D
    I am still messing with CheatEngine trying to get some memory addresses but so far I think I have only found one which would be of no use for motion lol
  2. SilentChill
    20,601Coins
    OK I'm getting somewhere now I have the hook for the Heading
    I know there is 1000000's of results but I know the location as my computer crashed just before I got to save the address :(
    I have no idea what to do with it yet but its progress :p
    edit: I have restarted game 3 times and its the correct address also it only changes when you ghet in a car which is a bonus I suppose :)
  3. SilentChill
    20,601Coins
    Okay I now have SPEED location no pointers its a static address :p
    This is a slow and hard learning process :)
  4. Historiker
    9,205Coins
    You get this and you will be elevated to the rank of elite.....and then you can make us hundreds of other plugins....now.....so get busy.....quickly :grin
  5. SilentChill
    20,601Coins
    @Historiker haha I have no idea what I'm doing really but I'm getting there .....hopefully, maybe, possibly.
    I had to give up last night after 4 hours I got just Heading(Yaw) and Speed.
    Tonight I will try my hardest to get Pitch and Roll.
    153,944Coins
    +11,158 / 57 / -2
    Think of us all as a giant team cheering you on as you slave away @SilentChill, surely @value1 uses something like that or an obsession with puzzles to keep himself motivated to create and update plugins :grin
  7. SilentChill
    20,601Coins
    Haha @noorbeast at least @value1 knows what he's doing, unless he's been bluffing this whole time :p
    I've gone begging on gtaforums to see if someone can make a script to show all the accelerometers and Roll/pitch displayed on the game screen . Simple if you know how. It will make it easy then to get the right memory addresses ;)
  8. SilentChill
    20,601Coins
    I have found 3 more addresses but they arent stable the keep jumping to negative values and back to the correct ones, I am struggling lol
    Enough for tonight tho will have to try again tomorrow
  9. Pedro Pablo
    Pedro Pablo Active Member
    Software Developer
    Valparaiso, Chile
    599Coins
  10. Pedro Pablo
    Software Developer
    Valparaiso, Chile
    599Coins
  11. SilentChill
    20,601Coins
    I have got a mod for showing coords and stuff and changed it to get all the rotation values and vectors and also velocities. Problem is none of the velocity values are any good they go negative and positive with in the 360 degree heading. The rotation values I cannot find the base memory addresses I can find the value in CheatEngine but the value changes to something completely different before I can find the correct address.
  12. value1
    14,243Coins
    To convert the speed values from world coordinate system into local coordinate system, you must find the transformation matrix, a 3×3 matrix.
    To find stable values for rotation, you must find the pointers to the rotation memory location. There are a few examples in the forum for other simulations.
  13. SilentChill
    20,601Coins
    There is an entity matrix which should supply the correct values, I will have to write a little C# script and try and display them, i think i'm kinda getting my head around this.
    I have found all sorts of values apart from forces and the rotation angles which unfortunately are what I need.
    Would post a picture but im at work will update with one later
  14. value1
    14,243Coins
    You can calculate the Euler angles (pitch, roll and yaw) from the unity matrix :thumbs
  15. SilentChill
    20,601Coins
    Calcualte ??? Euler ??? WTF is that lolol will it not just give me numbers automatically ;) best dust my calculator off :D
    I will find them then I will let you do the math @value1 how does that sound :thumbs
  16. value1
    14,243Coins
    Typically pitch, roll and yaw are calculated from the unit vectors like
    Code:
    Pitch_MemHook = Atan2(Vector.Fy, Vector.Uy)
    Roll_MemHook = Asin(Vector.Ry)
    Yaw_MemHook = -Atan2(Vector.Rx, Vector.Rz)
    Depending on the coordinate/transformation matrix, the math varies.
    Surge, sway and heave are transformed from world to local coordinates like
    Code:
    Surge_MemHook = -(ax * Vector.Fx + ay * Vector.Fy + az * Vector.Fz)
    Sway_MemHook = -(ax * Vector.Rx + ay * Vector.Ry + az * Vector.Rz)
    Heave_MemHook = ax * Vector.Ux + ay * Vector.Uy + az * Vector.Uz
    Find stable pointers for speed/accelerations and to the transformation matrix and I can help you further (if I find the time ;) )
    • Informative Informative x 3
  17. SilentChill
    20,601Coins
    Wowzers lol . There's me just thinking some numbers going up and down would do lol
    Hopefully I will have a breakthrough soon ;)
    • Funny Funny x 2
    • Optimistic Optimistic x 1
