Hi all new to this
Discussion in 'New users start here - FAQ' started by Vdub180, Jan 21, 2016.
  1. Vdub180
    Vdub180 Member
    England
    148Coins
    Hi all new to this so wanted to start off by saying hi and I hope to start my simple diy motion sim electronics in post just stuck on wiper motors or actuators ordered my steel tubing, moto monster, anduro and potentiometers just gonna start from there
    153,053Coins
    +11,116 / 56 / -2
    So do you have a design sketch of what you plan to build?
  3. Vdub180
    Vdub180 Member
    England
    148Coins
    To be honest I'm just gonna make it up as I go along to start with probably use wood then once working I will make it with metal never done anything like this before so I'm just gonna see how it works out I'm sure I'll be bk on here very soon :)
  4. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Welcome to the club. There's plenty of info in the FAQs with everything you need.
    I pretty much made it up as I went along and I'm only a couple of steps away from finishing my frames and hardware. I just need to wire up and mount all the electronics and I'll be almost there. Don't underestimate how much work it takes to build a sim. There's a hell of a lot of factors to think about, right down to how to the pots are mounted to the motor shafts, how to balance the rig, how to make the pedals adjustable and much more.
    Good luck.
  5. Vdub180
    Vdub180 Member
    England
    148Coins
  6. Vdub180
    Vdub180 Member
    England
    148Coins
    I'm only going for a very basic build as it's my first motion sim I've got this at the moment but would like a bit more feel
  7. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    I have mk4 golf/bora wiper motors in my garage but decided not to use them. As far as I could tell they're slow and fairly weak but i think with the correct levers you might be able to make them work. I just saved up for the crab pot pulling motors from the canadian ebay. They worked out at around £250 for a set of 3 so I have 2dof and traction loss. I'll use a wiper motor for a belt tensioning system at some stage in the future.
  8. Vdub180
    Vdub180 Member
    England
    148Coins
    I'll get 2 and see how it goes as there cheep as chips
  9. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    True. You can get them for about £10 - £15 from most breakers. Make sure you read the guide on ground isolating them.
  10. Vdub180
    Vdub180 Member
    England
    148Coins
    Anduro and moto monster have come gonna get soldering tomorrow is there a way of testing I've done it right with out any motors also to get the games to work do I have to become a member to download the plugins like project cars and dirt rally
    153,053Coins
    +11,116 / 56 / -2
    @SeatTime advises that you could test with an oscilloscope but bench testing with a motor would likely be more convenient : http://www.xsimulator.net/community...otors-mms-and-arduinos.6948/page-8#post-81280
    You are already a registered member, here is a guide to how the coin system works: http://www.xsimulator.net/community/faq/how-to-download-plugins.2/
    I have donated enough coins so you can use them to purchase a week's access to all SimTools plugins here: http://www.xsimulator.net/community/shop/
  12. Vdub180
    Vdub180 Member
    England
    148Coins
    Thanks I really appreciate it hoofully over the next few weeks I should have somthing operating thanks again
  13. Vdub180
    Vdub180 Member
    England
    148Coins
    Just a little update I have now soldered my anduro and my moto monster installed sim tools and ordered x2 mk4 golf wipers but still waiting for my potentiometers to come then hopefully I be able to see somthing moving
  14. Vdub180
    Vdub180 Member
    England
    148Coins
    Can I download some software to help me build my frame for my sim
  15. Historiker
    9,214Coins
    If you are talking about Simtools and plugins you have enough coins to buy a download package and download them. If you are talking about games you can download the live for speed demo. The plugins for live for speed is included in Simtools.
  16. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    You can use any 3d modelling software but sketchup is handiest to get. I just used a few pics off the build threads on here and made it up as I went along. Started off welding the basic frame shapes and then made brackets for mounts and pivot points etc as I went.
    153,053Coins
    +11,116 / 56 / -2
  18. Vdub180
    Vdub180 Member
    England
    148Coins
    Thanks I'll try that now
  19. Vdub180
    Vdub180 Member
    England
    148Coins
    Frame built now just a bit more tinkering thanks all so far so good I think
    153,053Coins
    +11,116 / 56 / -2
    You have a limited amount of leverage with the motors mounted so close to the seat and with the rods attached so low.
    Keep an eye on the motors when loaded, as I expect they will get pretty hot fairly fast and may struggle with the load.
