Showroom Thrustmaster T500RS Motor Upgrade 65W to 85W - SUCCESS 01/23/16
Discussion in 'DIY peripherals' started by Pit, Dec 14, 2015.
Would you upgrade your T500RS and risk to void the guarantee in case of a successfully upgrade?
  1. Yes
    33 vote(s)
    82.5%
  2. No
    7 vote(s)
    17.5%
  1. Pit
    30,498Coins
  2. Pit
    30,498Coins
    IMO I am not able to dismantle the magnet and the belt pulley
  3. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    is the pulley made of metal?
    (just a thought .... some years ago i managed to remove a press fit pulley from a turntable motor after putting the motor in the freezer for some hours).
  4. Pit
    30,498Coins
    If somebody knows where to buy any timing pulleys please HELP :)
    EDIT: no more pulleys needed (see below)
  5. Pit
    30,498Coins
    Yes, it seems to be metal...great idea to try out the freezer...thank you :)
  6. pipis2015
    Athens, GREECE
    10,248Coins
  7. pipis2015
    Athens, GREECE
    10,248Coins
    How to remove and attach a pinion gear for RC helicopter motor
    • Useful Useful x 2
  8. Pit
    30,498Coins
  9. Pit
    30,498Coins
    wow, I'll try this as well. Seems easier to me.
  10. pipis2015
    Athens, GREECE
    10,248Coins
    you can cut to fit or put two in opposite if you want to increase the tooth width.
  11. Pit
    30,498Coins
    tataa
    The magnet cylinder is a little bit broken but not really damaged.
  12. Pit
    30,498Coins
    The upcoming weekend is tinker and solder time! The replacement motor is being to be delivered this morning, the wheel is dismantled and is waiting for the big baby :)
  13. Pit
    30,498Coins
    BTW I didn't find many information about the mosfets sticked on the board obviously they should handle up to 110A...theoretically.
  14. RacingMat
    21,059Coins
    Warning_sign.png Warning for sensitive people!
    In this topic, hardware is being hurt badly... with great contentment from the author :)
    • Funny Funny x 3
  15. Pit
    30,498Coins
  16. pipis2015
    Athens, GREECE
    10,248Coins
    one quick question.
    supposed you cant change the current flow and stay oem.
    if the bigger motor has bigger armature (coil), is that enough to produce more torque with the same (stock) amps?
  17. Pit
    30,498Coins
    we will see...
  18. SeatTime
    I like the 'mad scientists' stuff :thumbs, but this thread has no credibility, because you have not done a 3D render...:p.
  19. RacingMat
    21,059Coins
    and still nothing burnt...
    have you lost your touch? ;)
    • Funny Funny x 2
  20. Pit
    30,498Coins
    Tomorrow (or better said today) is my day of burning things ;)
    BTW what I expect from the stronger motor: less clipping.
