Showroom CXC inspired design!
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
  2. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
  3. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    There is many types of Arcade shifter the one you point to it yes it is two springs driven however the one I have it has a pin on the center of the shifter stick with a pressure point that goes up on a V shape metal and touch a plastic bumper witch I feel a car positive feeling, what I did not like is the knob it is plastic how ever I will replace it for a aluminum racing knob.
    I will take pictures of the inside, just remember you will find multiples types of Arcade shifters.
  4. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Yeh, I shared the link to the one you have. Its important to get one that recenters. Most cabinets use a high and a low so it stays forward or back
  5. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    Obviously we cannot understand each other.
    No worries.
    BTW...
    Thanks for the (wizardry) lesson. :)
  6. pipis2015
    Athens, GREECE
    10,248Coins
    It is a joke... In case this is misunderstood.
  7. Historiker
    9,214Coins
    @pipis2015 , you might also look into an industrial joystick. Many are two position with heavy duty springs for return to center. I hacked one for my simpit. Works great and has just enough resistance to make it feel realistic. Many to be found on Ebay for around the same price point.
  8. pipis2015
    Athens, GREECE
    10,248Coins
    Thanks all for the replies,
    I was not clear myself on the exact detail that I wanted to see.
    But I got the info I wanted.
    Of course It is easy to understand that a sequential shifter is a rod that pushes two opposite switches and is centered by some kind of spring mechanism.
    The thing that interests the average diy-er is the contraption that is incoporated in order to give the notchy feeling of the real life sequential shifter.
  9. Historiker
    9,214Coins
    @pipis2015 , this is on my 7 speed gated shifter but here is one way to get that "notchy" feeling when shifting. It will work for a sequential as well, just make the ramps shallower and have a strong return spring. I actually made a plate for the bottom to capture the rod for sequential with return springs to keep it centered. It had a lever to raise and lower it into position. That way I could switch between 7 speed to sequential. But I found that I preferred my sequential shifter higher on my simpit and the gated shifter low like a sports car.
    EDIT: Added link to Willinova's original DIY Shifter thread where I found this design.
    http://www.xsimulator.net/community/threads/diy-h-shifter-by-willynovi-working.2323/
    Sorry for highjacking your thread Milton, let me know and I will clean it up.
  10. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    No worries! This good info for me also!
  11. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Here is a video on the Arcade shifter:
  12. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
  13. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Anybody knows what are the best iRacing Track in the world?
  14. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    The wife walked in while I was watching that video... I had to explain it was a gear shifter!!
    • Funny Funny x 8
  15. fortissimo
    fortissimo Member
    france
    161Coins
    Grande réalisation et une grande idée
  16. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I had some issues with the Arcade shifter, the spring was too weak for the weight of the handle so i replaced the spring see video:
  17. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I need help! Somehow with out any reason Simtools game engine stops working during the game! This is very annoying anyone knows how to fix this?
    Any help will be very well appriciated...
  18. Archie
    Wollongong, NSW, AU
    3,797Coins
    I've seen this on Windows 10 when an update reset all my file permissions.
    I had to reset the Shortcut / exe to run with Admin privileges and that seemed to fix it for me.... Hopefully it's that simple for you.
  19. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Now is my computer is shutting down.
    153,053Coins
    +11,117 / 56 / -2
