Showroom CXC inspired design!
  1. Francisco Junior
    Francisco Junior Member
    Curitiba - Brasil
    285Coins
    Nice Job !!!
    Keep us updated this beautiful work.
  2. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    You are correct! About the seat movement i notice that it moves side to side just with out motors, i thing that is the reason of CXC installing a guide bar in front of the seat, see picture attached.
    I will try my best to installed the motors on the side of the rig.
  3. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    That side bar is more to help with rotational movement, not generally an issue with a seat mover but with a feet and seat mover you can get twists. It might help but I wouldnt bet on it.
  4. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    good point! i may stop by CXC sometine this month they are just about 2 hours from where i live i want to see if i can get more info about the simulator.
    Thanks for your good observations!
  5. bsft
    Oh good stuff if there is a CXC you can have a go on. As for the uni joint, look for a rear wheel drive car and cut up a tailshaft.
    Then weld plates on the end. It is a lot bigger uni that the cheap steering knuckle CXC uses. I mean really, a sim with a 600% markup and they cannot use a decent uni joint. Pfffttt...
    As for angle, depending on what you weigh, its a bit snug, but would still do the job, maybe bring the top connections in a bit. Try to get minimum 15 deg angle out from the sides if you can.
  6. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Hello everyone, i painted the Rig with automobile Clear Gloss paint i gave it 5 coats, but! before i painted i sanded only the outside metal that will be visible to everyone with a 120 grid sand disk so it looks like bare metal, i like it! It gives a stainless steal look.
    In person is stunning shinny looking. Also if you look closer i finish the nut holders for the side panels.
    See picture.
  7. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Here are some drawing I created.
  8. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
  9. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Front view
  10. Nick Moxley
    What are you planning for adjust ability on the pedal plate angle ?
  11. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Sliding rails.
  12. Nick Moxley
    What about the Rake or Angle of the pedals tho ?
  13. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    The angle of the pedals plate will be fixed to my liking unfurtunate i will not be able to create adjustment, maybe in the future once is done.
  14. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    this shows the angle of the seat bracket and angle of the motor connection bar to the seat see attached picture.
  15. Nick Moxley
    11 deg isn't ideal, I vote you make a small bracket to bring the motor's out another couple inches per side. That will be more in the range of what we want to see.
  16. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I move the motors outside the frame and with a 2 inch distance from the frame and now the angle is 16 degrees, would this work?
  17. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Why not put the motor arms to the outside? Should have good enough clearance if you put the gearbox to the front
    • Agree Agree x 3
  18. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Here is how I do mine...When my motors are off, I allow the arms to rest on the shaft.
  19. bsft
    @Milton Amaya , what do you weigh? You can get away with slightly less angle, but it depends on your weight.
    How about this idea for motor mounting?
    Mount motors inside, but have the rods connecting outside? That way you keep the frame compact.
    Damn, @shannonb1 got in a few seconds before me. :D
  20. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I need some help! please see those 3 designs and vote please?
