Romysim R /R-R par rul
Discussion in 'New users start here - FAQ' started by julien b, Oct 8, 2015.
  1. julien b
    julien b New Member
    TOURS
    282Coins
    bonjour a tours moi c julien je suisfrançais en region centre ;
    j ai 37 ans et je viens de mettre au point mon chassis 2 dof /3DOF
    tout mobile apres avoir longtemps essayer de faire fonctionner mon systeme sur " l autre " je me suis finalement laisser convaincre et je me lance avec simtool j avoue etre un peu perdu !!
    ça va passer !!
    153,920Coins
    +11,156 / 57 / -2
    Google Translate:
    hello laps I c I suisfrançais Julian area in the center ;
    I have 37 years and I have developed my frame 2 dof / 3DOF
    any mobile after having long trying to run my system on " the other " I finally persuaded me and I start with simtool I admit being a little lost !!
    it will pass !!
    Welcome @julien b.
    By all means post in French but in the main threads please also include a Google Translation, it helps members work out if you need some help.
    It is certainly and interesting design you have for your motion simulator and I look forward to hearing some more about it and what hardware you plan to use.
    SimTools is pretty easy once you get the basics and there is some great documentation plus a really active community here who can help out: http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
  3. julien b
    julien b New Member
    TOURS
    282Coins
    A big thank you to you for your donation c Noorbeast awesome I can now download the game to finally test plugins
  4. rul
    rul New Member
    323Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    here's a video of my first tests involved two motor only for my third recovery engine had a weakness and my letting go !! still quite SETTINGS notament for noise but nothing insurmountable to be continued ....
  5. zigzag49
    zigzag49 Active Member
    726Coins
    Clever mounting as why girls rods of arrears engines it on glissieres?
  6. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Quels sont les moteurs que tu utilises ?
    What drives you use?
  7. rul
    rul New Member
    323Coins
    tu peu me tutoyer momoclic !!!lol
    j en parle sur PCSHM mais en fait sa va me permettre de corriger se que j en avais dis car pas de plaque dessus je pensais que c' été des moteur 300W mais sa ne serai que 200 w vu mes mesures se sont des moteurs qui été sur un fauteuil roulant de reforme
    you can memoclic tu me !!! lol
    I speak on PCSHM but in fact it's going to allow me to correct is that I had to say no because I thought top plate c summer of 300W engine but its 200 w shall be only saw my actions have engines that was on a wheelchair reform
  8. rul
    rul New Member
    323Coins
    pour completer ma reponse en fait je pense que la rapidité viens de la conception du bras qui amplifie le déplacement vertivale pour une amplitude de presque 15 cm sur 75° de rotation pour l axe reducteur ,
    l amplitude du bras est reglable et surement a affiner j avoue quetes connaissance mmoclic m aurai bien servis a certains moment de la conception je suis en admiration devant letravail et l aide que tu apporte sur les forum !!
    j adorerai avoir ton avis d expert sur mon chassis .
  9. rul
    rul New Member
    323Coins
    to complete my answer actually I think just the speed of arm design that amplifies the movement vertivale for a range of almost 15 cm by 75 ° rotation for the shaft reducer,
    the amplitude of the arm is adjustable and has probably refine knowledge I confess quests mmoclic m have well served certain design time I am in awe letravail and helps you bring the forum !!
    I'd love to have your opinion on my expert frame
  10. rul
    rul New Member
    323Coins
    desolated for not speaking I always oversights
