Showroom Obutto Ozone 2DOF to 3DOF simulator conversion
Discussion in 'DIY Motion Simulator Projects' started by scalhoun, Jun 25, 2014.
  1. scalhoun
    scalhoun Active Member
    Software Engineer
    Pennsylvania
    968Coins
    Parts List:
    Cooler Master Elite 130 - $50
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119286
    Neutrik NL4FX - $18.99(4-pack)
    http://www.ebay.com/itm/231098514149?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Neutrik NL4MP - $11.95(4-pack) - You can also order these with screw option like the cable side has, these are solder version
    http://www.ebay.com/itm/330827471744?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Quick Connects for Motor side of power line:
    Tamiya Connector Pack, Female - $2.25
    https://www.pololu.com/product/1932
    Tamiya Connector Pack, Male - $2.25
    https://www.pololu.com/product/1933
    Quick Connects for keystone jacks in case and jrk feedback:
    0.1" (2.54mm) Crimp Connector Housing: 1x3-Pin 25-Pack - $0.79
    https://www.pololu.com/product/1902
    Female Crimp Pins for 0.1" Housings 100-Pack - $5.95
    https://www.pololu.com/product/1930
    0.100" (2.54 mm) Breakaway Male Header: 1×40-Pin, Straight, Black - $0.79
    https://www.pololu.com/product/965
    Estop w/key - $7.88
    http://www.ebay.com/itm/201190140543?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Cat6 or cat5 keystone jacks for case and mounted on pots
    Cat6 is is one gauge thicker wire than cat5 in the spec. So either will work, I had access to cat6 wire so I used it
    http://www.ebay.com/itm/10-pcs-set-...e-Plug-Cat6-/171356491941?hash=item27e5a490a5
    Switchcraft EHUSBBABX USB-B to USB-A Feedthru Panel Mount Jack, Black Finish - $6.05
    a
    mazon.com/gp/product/B00DJ4Q6FW?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
    HP Proliant DL380 G4 575W x 3 - $5-$25/piece
    These fit perfect in the case as you can see in the pics without taking them apart. @rundmg is now building his similar to mine using the bigger power supplies like @Nick Moxley uses, so he will have pictures once he is done of his took apart and mounted in case.
    Wiring:
    I used standard wiring from local hardware store. Power lines to motors are 2 wire 14awg. Custom estop cable uses 3 wire 12awg and 3 pc cable ends that are 1ft and the standard 18awg.
    3d file for back panel
    https://www.dropbox.com/s/zxf36dz43yhc72w/elite-130-jrk-plate.stl?dl=0
    • Like Like x 5
    153,950Coins
    +11,159 / 57 / -2
    Great list, thanks so much for taking the time to put it together, I am sure others will want to emulate such a clean and neat solution, I know I will.
    Next time you have the Coolmaster cover off can you grab some more photos of the internal layout?
  3. Nick Moxley
    Looks AWESOME man, BUT one concern i have, What are the Tamiya connector's for ? Those have a HIGH probability of melting and causing a Nuclear melt down. I suggest going with a Deans to be 100% safe. Fortunatly the tamiya's are cheap and so are Deans, But the difference in power handing capabilities is NIGHT and Day difference.
  4. Nick Moxley
    PS i would LOVE to see an In depth thread about the OSW and which thread your following to do so. Thanks.
  5. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    Used those on the motor side, so far they haven't got hot, but thanks for the heads up I'll keep an eye on them.
  6. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    I took an old power supply and removed the internals/lid and then cut one side off and kept the fan in it. Then just mounted to the rail as you see in pics. Inside of case is pretty simple. I need to get a smaller usb hub and shorter usb cables for the inside to clean that up, I had ordered a bunch of 6ft ones and was wishing i had 1-2 foot ones.
    The case did have a cd tray which I removed to make space, would have make a good place to mount jrks but it had a lot of holes so I said frack it and removed it.
    All the screws I used came with the case are in a bag of spare parts. (Except for the nylon spacers and screws used to mount the jrks to plate, I need to add those to the list from pololu.com
    You can see in my finished pictures in other post; I was able to just screw the power supplies in via the little holes on the back of the case.
    Let me know if any their are any angles I don't have that you want to see.
    IMG_1886.JPG IMG_1866.JPG IMG_1894.JPG IMG_1889.JPG IMG_1890.JPG IMG_1891.JPG IMG_1892.JPG IMG_1922.JPG IMG_1924.JPG IMG_1926.JPG IMG_1886.JPG IMG_1866.JPG IMG_1894.JPG IMG_1889.JPG IMG_1890.JPG IMG_1891.JPG IMG_1892.JPG IMG_1922.JPG IMG_1924.JPG IMG_1926.JPG
    • Winner Winner x 4
    153,950Coins
    +11,159 / 57 / -2
    As you say the PSUs are a perfect fit!
    Getting to the JRKs is also simple, should you ever need to swap one out.
    When I created my 'computer dock' I added a digital touch screen fan monitor with alarms, to keep an eye on the JRKs temperatures. The Coolmaster case even has enough room to incorporate thermal monitoring if you wanted to develop it further.
  8. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    I might ramble too long in this one.... be warned!
    I'll start a new thread on here for it and also include the custom bluetooth rim build, and give you guys the 3d files to print for it as well. It will have 7 push buttons, carbon fiber paddle shifters, and 2 toggle switches. Total cost is under $200 , closer to $150 actually including the rim.
    The main OSW build thread is mainly on the iracing forums, and can't be copied to other sites. Here is a link to to a tutorial most people start with, also where I ordered my carbon fiber paddle shifters.
    http://www.ascher-racing.com/opensimwheel/
    After tons of research and pricing everything its a no brainer. One of the guys behind it and really pushing it forward with custom boards/etc just started selling a DIY kit.
    I made a parts list and my cost was going to be like $1200-1300 and 3-4 weeks of waiting for parts.
    This guys name is Ollie and he sells a full kit that is ready to be mounted into a computer case (most ppl use the same elite 130 cooler master) No soldering, everything is done. You just mount it all and connect things following his instructions and then reference the forums for the software side of setting things up. He has sold at least 100 kits that I'm aware of, might be closer to 200 now.
    Seems like he is 4-6 weeks out on orders so you just get put on a list and don't have to pay until your unit is ready to ship and he sends the invoice.
    My total price shipped from Germany is $1125 to US so it was a no-brainer. @rundmg has one coming too. I can get you his email if you want to get added to the list.
    Below is an image of a recent kit one of the guys got from him. Once his custom board is in production you won't need half the boards in this pictures though. Hoping my order will have it :) Obviously the laptop and soldering iron isn't included...
    It comes with the small mig servo, will do 20nm of force, some guys are pushing it to 25-29 but have no idea how long it will last pushing it over 20. From what I hear we are talking about enough power to break your wrists in a wreck if you don't let go when you go over 20nm. It's not so much the power I really want it's the level of detail this thing offers.
    Did you watch the The Sim Garage comparison video? It stirred up all kinds of mayham and trolling in the forums.
  9. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    Haha yeah I need to check that out, I've been popping the lid every so often mid race to check and feel the heat sinks to make sure we are good. lol
    So far it's been fine though, I've burnt enough jrks up for a lifetime.
  10. Nick Moxley
    Awesome job on the Coolmaster case, VERY clean. Ya get rid of those 6' extensions and go for 1.5' or even shorter to clean it up real nice.
    F i really wish the Canuck dollar wasn't so Garbage right now or i would JUMP all over that deal....1300$ isn't that bad AT all.
    As for NM rating's on motor's.....I can 1000% agree that 20nm and up will break fingers and more than likely worse if your not careful......My CSW after the buhler upgrade actually injured my thumb on one of the first outing's....Not paying attention to how much force was REALLY hiding there waiting for me.
    here's the chart for sheer reference
    The resultant effect of the stronger motors is as follows:
    Stock motors @24VDC pulled 8.5 pounds@~5.38"R. So about 3.8 lbs./ft. (5.2 Nm) of torque.
    With the Buhler motors @24VDC pulled 14.5 pounds@~5.38"R. or 6.5lbs./ft. (8.8Nm).
    Buhler motors @30VDC pulled 18.25 pounds@~5.38"R. or 8.2lbs./ft. (11.1Nm). *****Mine
    New test:
    Buhlers @40VDC pulled 21.25 pounds@~5.38"R. or 9.53lbs./ft. (12.9N•m)
  11. ho123
    ho123 New Member
    belgium
    198Coins
    Arduino, 6DOF
    nice project keep up the good work.
  12. Sebj
    Sebj Active Member
    Canada
    492Coins
    @scalhoun , nice build! I'm also going with the elite 130 case idea as I wait for my OSW :)
    Do you still plan to post the 3D file for the back panel?
    Glad to see that 14AWG wire runs work fine for the motors at the length you have them at.
  13. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
  14. Sebj
    Sebj Active Member
    Canada
    492Coins
    Thanks @scalhoun , btw how is the OSW wheel project going?
  15. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
  16. Sebj
    Sebj Active Member
    Canada
    492Coins
    @scalhoun Can I trouble you to export that back plate file into STEP or IGES format or a 2D DWG format? I will want to get it laser cut but need it converted to those file types.
    • Old Old x 1
  17. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    Does the original autocad dwg file work? I can look for the other format exports quick, just never used them so not sure yet.
  18. Sebj
    Sebj Active Member
    Canada
    492Coins
    That should work thank you.
  19. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    This work?
  20. Sebj
    Sebj Active Member
    Canada
    492Coins
    thank you
