Tutorial Hydraulic handbrake converted to load-cell
Discussion in 'DIY peripherals' started by RacingMat, Sep 10, 2015.
  1. RacingMat
    20,876Coins
    for more information on load-cell, have a look here
    Working with load-cells
    http://www.xsimulator.net/community/posts/86673/
  2. tombo
    tombo Active Member
    2,436Coins
    DC motor, Arduino
    I've just read you want to replace your french damper.
    Maybe something like this would be good. They are used in Automobile industrie. Open the trunk at your car and you can see them.
    The should be really the same diameter. I use them on my handbrake and it gives a good feel. You can tets it with the ones from your car. you can turn them out by hand like a screw.
    http://www.ebay.de/itm/vw-kaefer-2x-Anschlaggummi-Motorhaube-Gummi-0768-/171389308293
    • Creative Creative x 2
  3. jaco73
    jaco73
    wing awaiting mine, and I'll try the concersion.
    thanks for the tutorial:thumbs
  4. RacingMat
    20,876Coins
    I had to add a spring behind the load-cell in order to come back to zero value.
    Without spring, the handbrake was seen as still braking by windows controller.
    It very good now and I think it is finished. :cheers
    Hopefully I have other sim projects awaiting me!
    • Like Like x 5
