Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. BlazinH
    16,574Coins
    Yes @bsft, its in the game folder where you applied the patch. I believe you need extradata 3 for gamedash to work. Are you using the latest plugin? I think there are or were two of them. http://forums.codemasters.com/discussion/6550/dirt-rally-erratic-annd-jittery-motion-telemetry
  2. bsft
    @BlazinH , I downloaded the plugin a week ago, so unless its changed.
    Ok thanks, I will go change that number in the line of code and give it a try.
    Cheers
  3. bsft
    @BlazinH , @value1 , nope, sorry, extra data is 3, plugin is latest. Still causing game dash to crash on start up of game, otherwise, motion works just fine. Just no game dash. Only gauge on screen in game.
  4. danone38
    danone38 New Member
    - 291Coins
    I am new on the site and I too installed(settled) well the plugiciel last one, I have the movement which works but not the GI max with simdash. I marked well the dash out in simtools. I do not understand why
  5. bsft
    They might be ignoring us.....or just leaving it till next release ( soon hopefully ) of Simtools. ;)
  6. jimmytm3
    jimmytm3 Member
    Boilermaker
    macksville, New South Wales Australia
    171Coins
    2DOF, Arduino, JRK
    has anybody lost motion since the last update of dirt rally it kicks in on start up then no movement in game play reinstalled patch still nothing any ideas cheers
  7. value1
    14,497Coins
    Works fine here:
  8. jimmytm3
    jimmytm3 Member
    Boilermaker
    171Coins
    2DOF, Arduino, JRK
    weird i have no idea what to do
  9. jimmytm3
    jimmytm3 Member
    Boilermaker
    171Coins
    2DOF, Arduino, JRK
    would you have any idea what may have happened ? there is no data at all coming through in the tuning center . I racing works fine so its nothing to do with the hardware tried re patching again nothing ? don't want to be a pain!
  10. bsft
    There are different versions of the game depending on what part of the planet you are on. Probably why the dash works in the north, but not for us in the south.
    It could be the same with the updates, they tend to flow through different parts of the planet in different ways.
    That being said, I have not played it for a week and I am not sure of any updates.
    I will have a look later and let people know.
  11. bsft
    Works fine here, I am not sure if any steam updates have been applied though to the game. I only installed Project Cars 2 days ago and I can find no updates for Dirt Rally.
    But BOTH still crash Game Dash on start of game.
    I am being suspicious of Windows 7 and its recent updates though. Garage Sim PC is running 7 64 bit genuine, but I have not updated windows for about 4-5 months.
    Theres been discussion of windows 7 updates starting to crash certain programs, like Skype.
    So I dunno, maybe try system restore back a few weeks. Maybe a recent windows update might be causing a bug.
  12. Romain Seignour
    Romain Seignour Member
    - 115Coins
    run fine for me ! i think the problem is not update !
  13. jimmytm3
    jimmytm3 Member
    Boilermaker
    171Coins
    2DOF, Arduino, JRK
    All fixed had to get the newer plugin downloaded the one first week it was released something must have changed or the plugin was corrupted some how but any way all good except my wheel and peddles are glitchy first runs fine but when you restart the run it gets glitchy must be a pc problem frame rates get slow and glitchy too only dirt rally for some reason
  14. Romain Seignour
    - 115Coins
    you can download again a plug in and repatch the game in documents you know ? i had the same problem the last week !
  15. Vboull
    Vboull New Member
    181Coins
    Thank you for this plugin, it's a good job.
  16. abah_masha
    abah_masha New Member
    Indonesia
    130Coins
    Thank's.. for plugin.. this is my first plugin by using my coins.. i willl try to my Dirt game..:cheers
  17. Romain Seignour
    - 115Coins
    @abah_masha you must think to download your future game plug in before your end of your purchase !! ^^
    have a nice motion !!
  18. abah_masha
    Indonesia
    130Coins
    What's wrong with me.. in my game manager still "Connected" which should "Game Runing"... see my pict!
    (sorry.. whether previously been discussed... sorry too, if I post reply here.. )
  19. Romain Seignour
    - 115Coins
    your code is not the same to mine in interface output you use the arduino uno ?
  20. Romain Seignour
    - 115Coins
    and your game manadger is not in running mode is not normal when you have patched your game do you have the windows "game patched "?
