Tutorial Hydraulic handbrake converted to load-cell
Discussion in 'DIY peripherals' started by RacingMat, Sep 10, 2015.
  1. RacingMat
    21,061Coins
    • Like Like x 5
  2. RacingMat
    21,061Coins
    shopping list
    eBay 33€
    "HYDRAULIC HAND BRAKE WITH PUMP S14 S15 AE86 RX7 DRIFT HORIZONTAL VERTICAL RED"
    http://www.ebay.fr/itm/HYDRAULIC-HA...ERTICAL-RED-/311068773989?hash=item486d24ce65
    load-cell amplifier - HX711
    communicates in SPI with an arduino for example
    www.arduino.cc/en/Reference/SPI
    0,69€
    http://www.aliexpress.com/item/For-Arduino-Dual-channel-HX711-Weighing-Pressure-Sensor-24-bit-Precision-A-D-Module/32323968927.html
    ____________________________
    http://fr.aliexpress.com/item/20kg-....tmeRpX&ws_ab_test=201407_2,201444_6,201409_3
    4,87€ load cell 20kg
  3. RacingMat
    21,061Coins
  4. RacingMat
    21,061Coins
    Building steps:
    635319Freinamainloadcell1.jpg 588279Freinamainloadcell3.jpg 188311Freinamainloadcell6.jpg 115823freinamainloadcell6.png 433876freinamainloadcell4.png IMG_1173.JPG IMG_1172.JPG
    I had to add a spring behind the load-cell in order to come back to zero value.
    Without spring, the handbrake was seen as still braking by windows controller.
    It very good now and I think it is finished. :cheers
    Hopefully I have other sim projects awaiting me!
  5. RacingMat
    21,061Coins
    First video:
  6. RacingMat
    21,061Coins
    Link to PC
    via CSP pedal handbrake analog comport
    this pinout from https://www.gtplanet.net/forum/threads/clubsport-and-csr-elite-pedals-handbrake-diy-info.280445/
    Thanks to Mrbasher, here is how I wired the hand brake onto the PCB
  7. RacingMat
    21,061Coins
    [reserved Work In Progress]
    152,676Coins
    +11,089 / 56 / -2
    Nice work @RacingMat :thumbs
    From the video it seems to have good 'feel', like you would expect in a hydraulic system, does that translate well in a game?
  9. RacingMat
    21,061Coins
    Thanks @noorbeast!
    Yes, the feeling is good. But I'll replace the "french" damper 964382Freinamain24.jpg
    by a harder damper in order to reduce the range of motion of the handle.
    It's adjustable.
    It's not yet wired to be connected to PC. Probably this week-end ;)
    Any hint for CSP pinout? @HoiHman @Nick Moxley
  10. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    interesting project. At the moment I'm on vecacion. At sundy I'm back home and can take a look at my csp for pinout.
  11. Nick Moxley
    Nah never got into the Pin out of the PCB, sorry matt.
    If you still need a hand i can ask around, Jon from Basherboard would 100% know for sure.
    What EXACTLY do you want to know ?
  12. Historiker
    9,208Coins
    Mat, Pin 2 is the sweeper from the pot so yes it reads the voltage change. I did this mod on my Fanatec Elite pedals as well. Then I switched to a Teensie ++2.0 instead when I built my button box/shifter
  13. RacingMat
    21,061Coins
    As I didn't find any spedification from Fanatec documentation,
    before wiring, I'm just worried about the little mistake written in the post https://www.gtplanet.net/forum/threads/clubsport-and-csr-elite-pedals-handbrake-diy-info.280445/
    Like Historikr, I think it should be pin 2.
    I'm interested in your feedback! and Jon's expert information on how to plug an analogic handbrake on the CSP V2.
  14. Historiker
    9,208Coins
    Mat, use a volt/ohm meter with the board plugged in and check the pins for voltage.
  15. Nick Moxley
    Jon can be reached here http://www.basherboards.com/contact
    If you want to drop my name, Go for it. Jon's a good guy and actually sold me my First EVER fanatec product, The V2's. :thumbs
    • Friendly Friendly x 2
  16. RacingMat
    21,061Coins
    Thanks Nick!
    Ok, I have had a look with the voltmeter: look.gif
    nada...
    but when i check between pin 1 and 3, then the throttle adn brake are varying in windows controler...
    Then I lost my throttle and I had to restart twice to get it back... but no voltage
  17. RacingMat
    21,061Coins
    Finally, I didn't manage to read any voltage... but I wired the handbrake: it works!! spasibo.gif
    I'll post some pictures
  18. RacingMat
    21,061Coins
    It works fine!
    Here is the pinout with colored wires
    • Useful Useful x 2
  19. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    Really nice work. :thumbs
    I have many loadcells laying around as replacement for Fanatec Break pedal.
    So I have a question. In the pedal thread you wrote you need two loadcells for a Bridge.
    You use only one. Does your lodcell internally consits of two?
    Sorry but I never worked with loadcells.
  20. Nick Moxley
    the Fanatec Cells are only a 1/2 bridge as i understand.
