Showroom Prototype 6dof
Discussion in 'DIY Motion Simulator Projects' started by NjMotion, Jan 13, 2014.
  1. Tino
    Tino Member
    1,289Coins
    There are commercial versions available, like (ckas for example), but they cost more money.
    If you are on a budget then (unfortunately) for now DIY is the way...
    Also I think it's actually fun to build a simulator, you will learn a lot and it's worth the effort.
    @CalSim Thanks, I've got these cheap servos from ebay:
    £1.29, free shipping!
    Operating Speed (4.8V no load): 0.12sec/60 degrees
    Stall Torque : 1.2kg / 42.3oz(4.8V);1.6 kg / 56.4oz (6.0V)
    http://www.ebay.co.uk/itm/400762702702?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    I'll be getting the controller soon, at the moment I'm deciding between getting laser cut Plexiglas or 3d printing the platform.
  2. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Impressive project, thanks for sharing!
  3. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Wow impressive, nice work!:thumbs most of us doing a 2dof version 6dof is the bom!
  4. NjMotion
    España
    1,500Coins
    2DOF, 6DOF
    Thanks friends :thumbs
  5. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    Hey! it's awesome! I'm a newbie here,Do not know when can i to build such a high-end 6DOF
  6. sebastian cajarville
    sebastian cajarville New Member
    Maldonado, Uruguay
    249Coins
    2DOF, 3DOF, Arduino
    es excelente espero algun dia poder lograrlo por ahora estoy comenzando con 2dof , exitos
  7. sebastian cajarville
    Maldonado, Uruguay
    249Coins
    2DOF, 3DOF, Arduino
    Excellent hope one day I can do for now I'm starting with 2dof, successes
  8. jakubzik
    jakubzik Member
    CZ
    33Coins
    :O super project :3
  9. vulbas
    vulbas Active Member
    france
    1,096Coins
    AC motor, 6DOF
    Can you you'd be sharing an axis configuration file. I am curious how it is done. the mine is not at all the same.
  10. townnet
    townnet New Member
    Singapore
    400Coins
    That is cool, thanks for sharing.:)
  11. Blugreen
    Blugreen New Member
    477Coins
    Awesome work.
  12. zigzag49
    zigzag49 Active Member
    705Coins
    pity there is more new simulator, an interesting project, good job.
  13. NjMotion
    España
    1,500Coins
    2DOF, 6DOF
    Vulvas sorry for not answering earlier.
    The axis assignment is the public, handed it to me and then retouched Historyker my taste but that and makes the movements very well, which can vary is the direction of the engines by way of connection but no more.
  14. zigzag49
    705Coins
    Is it possible to see your new setting. :blush
    No particular concern since it put into operation? Thank you, anyway good job.
  15. NjMotion
    España
    1,500Coins
    2DOF, 6DOF
    Thank, zigzag49.
    The setting is the same as there are published only change something in the front motors turns on curves, and yaw for the extra 1.
  16. zigzag49
    705Coins
    OK thank you .
    That brings a big plus 1 extra?
    It would be cool new video;)
  17. NjMotion
    España
    1,500Coins
    2DOF, 6DOF
    Now I do not have it operating, for lack of space.
    I'm sorry.
  18. zigzag49
    705Coins
    Ok;)
  19. AlexinChina
    AlexinChina Member
    China
    371Coins
    nice project! very detailed !thanks for your share
  20. AlexinChina
    AlexinChina Member
    China
    371Coins
    Why we almost use monstersheild to drive motor ? It's voltage is too low! 12v motor which has high power,such as 500w,is hard to get。
    why not use 220v drive ?if we use 220v drive, we can use more power easily.
    So can anyone introduce a 220v drive to me?
