help I do not know what to do Arduino + sabertooth
Discussion in 'DIY Motion Simulator Projects' started by dualclick76, Jul 12, 2015.
  1. dualclick76
    dualclick76 Active Member
    italia
    11Coins
  2. dualclick76
    italia
    11Coins
  3. dualclick76
    italia
    11Coins
    Another problem, sim tools work only if the sabertooth is connected with USB. the sabertooth connects and disconnects from usb continuously.
  4. dualclick76
    italia
    11Coins
    my dip switch is: 1 off 2off 3 on 4 off 5 on 6 on;
  5. dualclick76
    italia
    11Coins
    code arduino :XPID_SimTools1_23
  6. dualclick76
    italia
    11Coins
    describe the software load the file sabertooth 38400, going on to see real-time diagnostics crashes descrirbe
  7. BlazinH
    16,671Coins
    I wish I could be of help somehow but I'm out of ideas because I'm not understanding your issues good enough to do so.
  8. Wanegain
    Wanegain Active Member
    Bruxelles
    2,012Coins
    You don't need to connect the Sabertooth with USB.
    You can try to invert the plugs on your motor which is heating.
  9. dualclick76
    italia
    11Coins
    help help help
    guys i need your help do not abandon me. current situation sim seems to work, but it only works if the sabertooth is connected with USB.
    The sabertooth connects and disconnects constantly. Arduino code that works is XPID_SimTools1_23_2x32, the DIP switches are set as follows: 1 off; 2 off; 3 on; 4 on; 5 on; 6 on. DESCRIBE with the software I set the baud rate 115200 HELP HELP HELP HELP
  10. telfel
    telfel Active Member
    4,738Coins
    Hi
    Have you thought about using DE Kangaroo instead of the arduino
    regards Terry
  11. Wanegain
    Bruxelles
    2,012Coins
    Set the baudrate at 38400!
    I'm on vacation with a limited Internet connection...
  12. dualclick76
    italia
    11Coins
    boys I still need your help, I noticed that I turn on the simulator start simtools I press you turn on Arduino LED rx on; when I try roll or pitch or yaw, or any other dof Arduino by a small movement signal then turns off the LED rx therefore no other type of movement
  13. dualclick76
    italia
    11Coins
    UPDATE: I was able to isolate the problem but do not know how to solve. I try to explain; I have tried to cut the power to the motor 2, start the sim, start simtools works great. The moment also connect the engine 2 turns off the signal rx and Arduino stops rotating only in one direction of the potentiometer. help me please let
  14. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    i had the same issue, problem was a USB cable ! Too long, weak contact, i just replaced it with new one and problem is gone
