knaufinator
BeamNG.drive plugin 2.0.3.0
Simtools game plugin for BeamNG.drive
  1. prilad
    Dubna, Russia
    9,667Coins
    3DOF, DC motor, Arduino, 4DOF
    prilad submitted a new resource:
    BeamNG.drive plugin - Simtools game plugin for BeamNG.drive
  2. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Thank you guys !!! it's working very well on Steam, no problem at all . Only one question , does it work on non Steam version? if yes ,then how to run it, because i have tried but with no luck . How to toggle ON the socket output in the game without Steam ?
  3. prilad
    Dubna, Russia
    9,667Coins
    I update "Important" information on resource page ;)
    - For "local" version (without Steam) simply run "BeamNG.drive.exe" with parameter "-luasocket".
    I've made a *.bat file includes this string:
    C:\"Program Files (x86)"\Steam\SteamApps\common\
    BeamNG.drive\BeamNG.drive.exe -luasocket
  4. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Thank you again ! It's working. Now it's time for demolition !!! :D
  5. value1
    14,244Coins
    • Like Like x 5
    153,950Coins
    +11,159 / 57 / -2
    So cool, thanks for sharing @value1
  7. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    I face up with some problem on new BeamNG version, i can't install a patch because in new version default.lua is missing, could you please check this error. Game version 0.4.0.6 and all versions higher.
  8. value1
    14,244Coins
    Hi @auryza
    You're right. There was a change in the file structure of BeamNG. We will fix the plugin ASAP
  9. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Thank you in advance.
  10. value1
    14,244Coins
  11. prilad
    Dubna, Russia
    9,667Coins
  12. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    It's working again !!! Good work, again !
  13. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @Fernanda,
    A word of warning, meaningless posts just to get coins could end up with a ban from the forum.
    Instead, read all the posts, you may find something that you can use. By all means ask questions
    And members will help if they can. But don't spam the forum, it's annoying! For every post that you
    read you will get a coin. It soon mounts up.
    Mike
  14. brucewang
    brucewang New Member
    China
    195Coins
    I dont know how to get the game
    • Dislike Dislike x 1
    153,950Coins
    +11,159 / 57 / -2
    You can get BeamNG from here: http://www.beamng.com/
  16. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    Hello. Is the plugin still compatible with the latest version 0.51? I've been unable to get motion so far (i added the -luasocket to the launch options in steam).
    Thanks!
    153,950Coins
    +11,159 / 57 / -2
    I am out all day today with friends but if nobody else gets around to checking for you then I will fire it up tomorrow.
  18. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    I have no motion on 0.5.1 @darkcrayon.
    When patching I get an error:
    System.IO.FileNotFoundException: Could not find file 'E:\SteamLibrary\SteamApps\common\BeamNG.drive\lua\vehicle\default.lua'
    I am guessing there are some pretty fundamental changes to how the lua files are now laid out, so hopefully @value1 will have a look when he has time.
  19. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hallo @value1, @prilad,
    @noorbeast is right, plugin does not working any more, i have tried already with 0.5.3 version of game. no luck. Please could you check what is wrong with plugin .
  20. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hallo guys,
    Could you please check what is wrong with this plugin . thanks in advance.
