2DOF + Arduino + MotoMonsterShield + Item Aluminium Square Tube + steel tube + Fanatec wheel pedal
Discussion in 'DIY Motion Simulator Projects' started by hape, Aug 8, 2015.
  1. hape
    hape New Member
    565Coins
    hi @all
    i'm on the way building this. I'm waiting for the MotoMonsterShield. I have already the Motors mentioned from RacingMat. I also build the seat from the Item square tube complete. So the part of the steel frame for the motion has to be done.
    I have never electro-weld anything so has someone also done this the first time and is it possible because i have to buy the electro-weld equipment. Any suggestions to that would be nice.
    Is it a good idea to buy a used cardan-shaft from the srap yard or are there other better and/or cheaper solutions?
    Is the program for the Arduino also included in the downloadable package from XSimulator?
    So many questions at the beginning. If i have the permission i will also post some pictures of what i have done so far.
    so long
    hape
  2. eaorobbie
    20,488Coins
    Welcome @hape looks like ya will have it happening soon.
    1. MIG welding is not hard a little practice, once setup its basically point and shoot.
    2. I only use a tail shaft from a rear axle driven car , as front wheel drive unis tend to twist. Even an old broken prop shaft from a tractor linkage is a strong option.
    3. Ard code look here - http://www.xsimulator.net/community/forums/simtools-compatible-interfaces.25/
    my fav - SMC3
    4. Add pic by dragging and dropping to post and videos can be freely added too.
    Again welcome and thanks for sharing.
  3. hape
    hape New Member
    565Coins
    hi
    thats what i have now (also the electronic is ready to go i only need the software to drive it and the motion steel hardware)
    so this works well as is.
    hape
