Large footprint 6DOF motion base ......
Discussion in 'DIY Motion Simulator Projects' started by jthiani, Jun 16, 2015.
  1. Fredrik J
    Fredrik J Member
    Sweden
    806Coins
    I just Wonder abort the Cost for The motors and controller.
    Just for comparison.
    Freddie
  2. SeatTime
    28,370Coins
    A sim like this will suck in as much money as you want to throw at it :p.
  3. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    DC motor, AC motor, Motion platform, 6DOF
    suffice to say the cost is depressing hahahaha
  4. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    well actually i have not as i am new to this forum, however even if i am presented with alternative controllers, i would still use the thanos controller as he has been a valuable source of information and wayyyy more helpful than i ever expected. So i will remain with the Thanos controller even in the future.
  5. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    amen to that ..... i even stopped tracking the cost hahahahahahaha
  6. SeatTime
    28,370Coins
    And it is not just the hardware costs - 6 x 2000W inverters = 12000w of power:eek:. You would have to have a chat with your local electricity supplier before you connected something like this to any mains house wiring.
  7. Fredrik J
    Fredrik J Member
    Sweden
    806Coins
    Just hotwire it to The neighbours Electric post
    • Funny Funny x 4
  8. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    Hahahahahaha ... might have to hire you for this !!!
  9. Fredrik J
    Fredrik J Member
    Sweden
    806Coins
  10. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,060Coins
    1200W is about 10A @ 110V AC (depending on PF) so would be similar to running an older style ducted air conditioner or electric water heater.
  11. SeatTime
    28,370Coins
    Your missing a zero :) - 12000W ....:eek:.
  12. Alexey
    Adelaide, Australia
    8,060Coins
    Mother of god.....
  13. vulbas
    vulbas Active Member
    france
    1,096Coins
    AC motor, 6DOF
    :popcorn
  14. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,916Coins
    I know exactly what you're talking about ... as your opinion is based on that you're new on this forum as I was three years ago ...
    So you found someone that guides you ... that's OK ... But, only to his way with no highway options ...
    As you may already noticed that he didn't introduce you to the other published controllers and the already finished projects to copy or to be informed more with them at least ...
    So you have nothing to lose I guess ... stay with his controller ... plus look around for more and you'll be enriched with all information you need ... or just add a question !!!
    And I can assure you that the FAQ section will be your best trusted friend you've ever had .
  15. Mmcool
    Mmcool Member
    USA
    1,174Coins
    @speedy So what you suggest to use for this kind of platform?
    Some requirements though:
    -safety
    -ease of setup
    -easy connections
    -compatibility
    I'm not electrician and have no knowledge of electronics... Anything off the shelve would be best!
    Mike
  16. RacingMat
    20,876Coins
    What's up? What's new? :)
  17. Eagletrike
    Eagletrike New Member SimAxe Beta Tester Gold Contributor
    Let you know when I grow up
    Central Western, New South Wales, Australia
    363Coins
    DC motor, SimAxe, 4DOF
    Oh My God what a mammoth project, :popcorn
  18. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    :popcorn
    Here for the updates :thumbs
  19. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    Soooooo i have been working on my motion base and have gone for a significant re-design. Basically i scrapped the idea of a pod mounted on top of the arms and opted for a basket design instead. The reasoning behind this is vast. First of all the head room required. i would not be able to use a room with anything less than 24 feet of head room. Second i know it has been done before but i just don't like the super high center of gravity and going with a basket design significantly lowers the center of gravity. So i took the whole rig apart and went to work with the band saw and welder. First try turned out to be waaayyyyy too big so i had to reduce the basket size in order to reduce the total foot print. second try went really well and i ended up with a 10 foot foot print which i am much happier with. Ok enough blabbing .....
  20. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    So this first image is the first mock up of the basket. it was a little bigger than i expected it to be, but i went ahead and put it all together the get the true scale .....
    The double uprights are at the front and will be used to hold the foot pedals in place
    20150729_140923.jpg 20150729_171927.jpg 20150729_172210.jpg 20150729_180219.jpg
    • Like Like x 6
