link Arduino to MM ?
Discussion in 'Electronic and hardware generally' started by Andrea 1968, Jul 14, 2015.
  1. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    hi, could you tell me with this file :
    Arduino code: 2DOF and 2 pins direction Hbridge 1.2 with presets
    RacingMat , November 8, 2013 , for Firmware Interfaces
    source code
    what kind of connection made between Arduino and MM for two engines ?
    Thanks.
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
  3. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    found , thanks for connection
    Arduino /..Motomonster1
    ....GND <-> GND pin
    .........5V <-> 5V
    .....pin 4 <-> pin 4 inA motor1
    .....pin 5 <-> pin 5 pwm1
    .....pin 6 <-> pin 6 pwm2
    .....pin 7 <-> pin 7 inA motor2
    .....pin 8 <-> pin 8 inB motor1
    .....pin 9 <-> pin 9 inB motor2
    .....pinA0 <-> center pin of pot 1
    .....pinA1 <-> center pin of pot 2
    .....pinGND <-> 0 ohm's pin potentiometer 1 & 2
    .....pin 5V <-> 10k ohm's pin potentiometer 1 & 2
  4. RacingMat
    21,042Coins
    Hello
    Glad you find the answer
    Please put a link instead of copy/paste
    It's easier to update or correct if the information is not spread in many places...
    Yours
    Mat
  5. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
  6. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    excuse my insistence , I can not understand the list of pins with the photo.
    in the picture there are pins on MM that on the list there are not , why ?
    and ' can do a bit of clarity , I not would burn some component ,
    await response to start connections between Arduino and MM ,
    Thank You
      68.5 KB
      619
  7. RacingMat
    21,042Coins
    there is no need to connect all the pins... only these :
  8. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    hi , thanks for reply , I still have Doubts about A1 and A0 , but do not go on Arduino ?
    Please could you take the attached picture and complete the connections of the potentiometers simply with the p a i n t .
    I'd appreciate it , thanks again and sorry insistence .
  9. RacingMat
    21,042Coins
    I don't really understand your sentence
    Pot1 on A0 (Analog 0)
    Pot2 on A1
  10. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    And so ' right?
  11. RacingMat
    21,042Coins
  12. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    hi, the tests carried out and watching the files of Arduino inputs are A4-A5
    as illustrated and everything works perfectly, thanks MAT
  13. RacingMat
    21,042Coins
    I wrote A4 and A5 in the code? I should correct the pinout
    but it's nice to have a look a the code anyway, and to understand what is done
