help I do not know what to do Arduino + sabertooth
Discussion in 'DIY Motion Simulator Projects' started by dualclick76, Jul 12, 2015.
  1. BlazinH
    16,665Coins
    Did you fix your dip switch settings? For Wanegain's sketch 1-off, 2-off, 3-on for psu, 4-off, 5-off, 6-on. Switch 4 is off to select the user defined baud rate from Describe. It appears it is set correctly at 38400 from your pics.
    Edit: I meant to say switch 5 should be off to select the user defined baud rate. But if using 38400 baud you must change the sketch and simtools to 38400 also.
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    I think the best things for you is to use my sketch even it's not optimised for your Sabertooh.
    Sabertooth has no autobaud, you need to set it like explain @BlazinH. You can use the file in attachment (rename the txt in tooth) to configure it with Describe.
    You need to set 38400 bauds and DIP switches are 1-OFF, 2-OFF, 3-ON, 4-OFF, 5-ON, 6-ON :
    If it's working, I'll explain you if you want what you need to edit in order to optimize the sketch for your Sabertooth.
  3. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    Immagine1.jpg Immagine2.jpg Immagine3.jpg Immagine4.jpg Immagine5.jpg Immagine6.jpg Immagine7.jpg Immagine8.jpg Immagine9.jpg Immagine10.jpg Immagine11.jpg Immagine12.jpg Immagine13.jpg Immagine14.jpg
  4. Wanegain
    Bruxelles
    2,003Coins
    For this sketch you need tout set the switch 5 ON !
  5. zigzag49
    zigzag49 Active Member
    723Coins
    DIP 5 on the address 128, switch position like giving higher by wanegain.
  6. Wanegain
    Bruxelles
    2,003Coins
    @zigzag49 : he's using currently the simplified serial, so there is no address :p
    Please try again with DIP 5-ON ;)
  7. zigzag49
    723Coins
    :confused:
    Pas tout suivi , je regarde en spectateur :popcorn
    Not everything followed, I look spectator
  8. dualclick76
    italia
    11Coins
  9. Wanegain
    Bruxelles
    2,003Coins
    Still no movement using Output testing (Axis output) ?
  10. dualclick76
    italia
    11Coins
    yes axis output nothing move
  11. Wanegain
    Bruxelles
    2,003Coins
    Your Arduino is on port COM13 ?
    Did you tested using DOF Output (in this case you need to fill the Default profile in Axis assignments) or Axis Output ?
  12. dualclick76
    italia
    11Coins
    yes com port 13 ,I tried it I used simtools with Arduino and moster moto shield
  13. Wanegain
    Bruxelles
    2,003Coins
    When you are testing, is the Windows of Arduino software open ? If yes, can you try to close it (it may lock the com port) ?
    When you press Start, do the motors make noise or vibrate ?
  14. dualclick76
    italia
    11Coins
    silence total
  15. dualclick76
    italia
    11Coins
    no Windows Arduino is closed after start
  16. Wanegain
    Bruxelles
    2,003Coins
    You need to close the Arduino software before Start
  17. dualclick76
    italia
    11Coins
  18. insanegr
    insanegr !N$@n€
    Athens
    16,723Coins
    hi i am not familiar with sabertooth but i can suggest few things.
    have read in here about com ports wont work if they are above com10 that's with SNC's but you can give it a try , another is that you have to make a profile (the default) to be able to test motion in game manager and another is to close all programs and leave only game manager for testing.
  19. dualclick76
    italia
    11Coins
    Arduino program is closed before operating simtools. I wondered if the led tx arduino must be switched off, because it seems to be the LED indicating transfer.
    my tx LED is off. my LED Rx (reception) is on
  20. zigzag49
    723Coins
    Very good question, its costs nothing to try.:thumbs
    Très bonne question,sa ne coûte rien d'essayer
