Move but not correct
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Kool7789, Jul 10, 2015.
  1. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    Dear experts,
    I'm so sorry by asking and asking again. Finally in sin tools in test the motion (my Frex motion) moves. Also feel a bit shaking in game in assetto Corsa. But below show the photo the angle of my chair is on a side. I had follow totally the instruction I dunno where went wrong.
    Hope someone can help me on this.
    Thanks in advance
    153,890Coins
    +11,154 / 57 / -2
    Can I clarify if the actuators move correctly when using the Output sliders for testing in the SimTools Game Engine?
    Can you please post screenshots of your settings.
  3. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    im not sure if I copy the correct file for you guys to see. Many thanks for your helps.
  4. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    image.jpg image.jpg I need to make it separately. I got nothing set in interface 3 and so on.
  5. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    Also include my pc some Datas
  6. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
    Anything I miss?
  7. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    I'm trying to copy screen as much as I can. If still something you need to have to check let me know.
    I know in quiet near to the motion movements.
    Hope it will be soon.
    Again thank you all so much for your kindly help. Thanks a lot. Have a nice weekend too.
  8. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    Normally when it start (in Straight back) I switch on the electricity the chair will move like the attached photo. Red to red arrow front and back and lean on a side after or Greeb to Green arrow. It seems depending the mood on which way.
    153,890Coins
    +11,154 / 57 / -2
    I did ask earlier if the actuators move correctly when using the Output sliders for testing in the SimTools Game Engine?
  10. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    i don't think so it moves correctly. Coz is not moving straight. And seems only one actuator is moving.
    once connect to game engine it moves one Conner side and to the other Conner side then stop like the first picture that i post it, instead moving forward and backward I think it should be.
  11. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    At the engine the below two columns (last two columns, seems is Yaw and another) slider it moves but just Conner to Conner and one way.
    It means my left back moves to forward right. And when I put it yaw a 100% and the other -100% the chair will be straight in that testing.
    153,890Coins
    +11,154 / 57 / -2
    So have I got it correct that only one actuator moves?
    It will likely be easier if you just post a video that shows the rig and screen at the same time, rather than trying to explain it.
  13. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    Yup. I will drop it tonight coz here is 2:57pm now and I'm out. I will upload it 6 hrs later. Sorry about that
  14. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    does one actuator only move? Did you check your wiring again or swap actuators not the power supply and the rs485?? Are you using one power supply per actuator?
  15. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    Yes I'm using the power supply by actuator.
  16. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    I just cut off the line of Simcon Motion and plug it into RS485.
    153,890Coins
    +11,154 / 57 / -2
  18. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    Yup this is what i had followed
  19. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    The first video from youtube is when i click the Simtools and he moves
    the second one is in the output setting. please refer to the youtube link below
    thanks in advance
    153,890Coins
    +11,154 / 57 / -2
