SimTools v2 - Game Dash v2.3
Format and Send Game Dash data to a device/program.
  1. eaorobbie
    20,503Coins
    Dirt 3 not supported but Grid2 should not be an issue but might not be implemented yet.
  2. eaorobbie
    20,503Coins
    Code exists if you search , just need to drive it with an RC signal, Read about that and you will find it.
  3. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Anyone got this working with Dirt Rally?
    Plugin says dash data is available, but I'm not getting any.
    Tried with @vthinsel 's CarDashX code, other games working fine, rFactor 2, Assetto Corsa, pCars, but Dirt Rally nothing.
    When I use Fanaleds for Fanatec leds, it uses port 30500 but leds are working, with Simtools no luck.
    <udp enabled="true" ip="127.0.0.1" port="4123" extradata="3" delay="1" />
  4. BlazinH
    16,689Coins
    Hi prodigy, I just got done with a session of dirt rally on my rig and dash data is working fine for me. However, I believe it was @bsft that reported his does not work either. I think it possibly has something to do with what region you downloaded it from steam from?
  5. bsft
    @prodigy and @BlazinH , thats correct, dash is not working with Dirt Rally or Project Cars for me. The start of the game causes the game dash program to crash.
    I believe its a region problem.
    Theres been several asks but its not being looked at I suspect until a possible next update of Simtools
  6. prodigy
    Croatia
    6,698Coins
    @BlazinH what's your extradata and other settins in config.xml of the game?
    Is it same like mine I wrote in post above?
    Also, what Ard code do you use?
  7. Steven Miles
    Steven Miles Member
    Portland, Or
    381Coins
    Nice! Thanks!
  8. mariana fino
    mariana fino
    Hi,anyone try to build a dashboard whith ard uno r3 and 2 rc servo motors,1 for rpm gauge another one to velocity gauge!just a simple analog dashboard i think...
  9. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
  10. mariana fino
    mariana fino
  11. ackemini
    ackemini New Member
    2Coins
    A silly question perhaps.. where can i find the Dash enabled game plugin for Assetto corsa and dirt rally?
    153,866Coins
    +11,154 / 57 / -2
    The GameDash functionality is built into the Assetto Corsa and Dirt Rally plugins.
    Assetto Cosa supports: DashApp Data:
    Speed [km/h], RPM, gear, shift light, fuel [lt], fuel [%], car model and track name. Additional values are feasible, yet not implemented: http://www.xsimulator.net/community/marketplace/asseto-corsa-plugin.10/
    Dirt Rally supports: DashApp Data:
    Speed, Gear, RPM: http://www.xsimulator.net/community/marketplace/codemasters-dirt-rally-plugin.140/
  13. piorck
    piorck Member
    french
    258Coins
    can this program run all display ?
    i'll have a SRD-9C .
  14. piorck
    piorck Member
    french
    258Coins
    no reponse ?
  15. yobuddy
    51,535Coins
    I'm guessing most people don't know what a SRD-9C dash is.
    Maybe post a pic and a little info about the dash.
    Otherwise your waiting for someone that owns one to answer, or your requiring someone to look it up, to know what your talking about.
    And most people just go on to the next post.
    Do you know how to communicate with the dash?
    Do you send it a string to set values?
  16. piorck
    piorck Member
    french
    258Coins
  17. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
    the srd-9c have a proprietary software for drive display from games
    "The SRD Manager 2 is a Windows based application used to manage the SimRDispXX and the SRD-XX dashboard display family"
  18. Lucio
    Lucio New Member
    Engineering
    Brazil
    190Coins
    hi all.
    i installed it but when i try to open the gamedash, i receive a error message: "gameplugins folder not found?" . why?
  19. yobuddy
    51,535Coins
    This resource has been removed and is no longer available for download.
  20. yobuddy
    51,535Coins
