My 2DOF Kit Build
Discussion in 'DIY Motion Simulator Projects' started by Paul Shortland, May 15, 2015.
  1. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Lots done today :thumbs
  2. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Thank you :)
    Final wiring today, hopefully then the scary switch on! plus the need for some software to run it :sos
  3. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    Good luck today! Looking forward to seeing it dancing!
  4. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Nearly ready, the build is finished, the wiring is complete. Just the software side to do now :grin
  5. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Slight hold up, can't download the iracing plugin :confused:
  6. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Why can't u download the plugin ?
  7. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    The button says download unavailable, don't know why :(
  8. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
  9. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Ah I see, i knew i had enough coins!
    Thank you :thumbs
    152,045Coins
    +11,062 / 56 / -2
  11. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    No problem ;)
  12. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Struggling today, presume this ATmega16U2 DFU driver problem could be at the heart of my troubles. Any ideas where I get an updated driver from or if I need to?
    Have read soooo many articles on this today!
  13. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    Did you install the latest version of Arduino software?
  14. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    What operating system and arduino board u using ?
  15. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
  16. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Final update of the day.
    Seems I had not connected to and amended the sabertooth board code. That is now done.
    Now both motors have power and if I use the output test they both move randomly but this does vary when I move the sliders. This is whichever way round I connect the pots.
    No idea how to progress from here but I have spent the whole weekend working on it and need a break.
    Any ideas gratefully received for what to try next, thank you all!
    :cheers
  17. Leo Burton
    London, UK
    2,639Coins
    Sounds like you're very close. If you can move the motors in output testing you are nearly there.
    Check the virtual output with game data as well. Make sure it's recieving telemetry.
  18. noorbeast
    152,045Coins
    +11,062 / 56 / -2
    Can you post some pictures of your settings, including those from SimTools.
  19. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Will do shortly, hope to have an hour or two over the next few evenings to carry on.
  20. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Decided to set up iracing and connect the two PCs tonight. All has gone ok and the virtual output is correct :thumbs
    Still have motor issues though, they keep rotating 2 or 3 x 360 degrees. Have set the roll and pitch to 20% each but still the rotating. The pots are connected to the right motors and the polarity seems ok too for the 24v to them.
    No more time tonight, but if anyone has any ideas on controlling the motors then I would be grateful :cheers
