My 2dof sim in progress
Discussion in 'DIY Motion Simulator Projects' started by alexis67, May 10, 2015.
  1. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    moi aussi a part la soudure :(
  2. alexis67
    alexis67 Member
    288Coins
    moi c'est ma spécialité :)
  3. alexis67
    alexis67 Member
    288Coins
  4. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    si j ai bien compris sa augmente la resistance des passages de vitesses c sa?
    if I have understood his increases the resistance of gearshifts
  5. alexis67
    alexis67 Member
    288Coins
    oui exact il va un peux plus dure
    exactly you need more force to shift
  6. alexis67
    alexis67 Member
    288Coins
    i have receive my doga motor and they look very good. they are original ground isolated and its very easy to put a screw for the potentiometer
    j'ai recu mes moteur doga ils on l'air vraiment bien , isolé de la terre d'origine et il suffit de percé pour mettre une vis pour les potentiometre
    easy to make a hole and a screw
  7. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    impec sa va bien avancer maintenant que t'a tes moteurs
    moi je reçois mon simu jeudi ou vendredi :thumbs
  8. alexis67
    alexis67 Member
    288Coins
    little work today
    petit avancé du jour
  9. alexis67
    alexis67 Member
    288Coins
    today i have work on the torque and the speed
    speed/2 and torqueX2
    réduction vitesse par 2 et doublage couple
  10. Pit
    30,479Coins
  11. alexis67
    alexis67 Member
    288Coins
    ok , today i have receive my sabertooth 2x32A , tested soon !
  12. dmk90
    dmk90 New Member
    Brisbane, Australia
    258Coins
    I like the handbrake!
  13. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    pourquoi a tu reduit la vitesse?
  14. alexis67
    alexis67 Member
    288Coins
    Jai mal lu la description du moteur. Il est pas asser puissant et trop rapide. La jai le double de couple
  15. alexis67
    alexis67 Member
    288Coins
    so next step is the electronic box
  16. RacingMat
    21,028Coins
    chain and pinions are dangerous: need a good boxing around
    Beware the trial phase when everything is unprotected and untested :confused:
    ça me fait peur cette chaîne et ces roues dentées : une machine à découper les doigts s'il n'y a pas de cache
    Attention particulièrement à la phase d'essais, pas de carénage, ça marche ça marche, ça part par surprise...
    bonne suite à toi :)
  17. alexis67
    alexis67 Member
    288Coins
    is not a problem i have tested today and the motor don't have the needed power ...
    i need other motors
    J'ai essayé et les moteurs sont trop faible , il me faut des autres moteurs !
  18. Cluclu
    Cluclu Member
    443Coins
    Bon courage dans ta réalisation Alexis ;)
  19. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    dommage pour les moteur en plus s'est vrai sa fait un peut peur pour les doigts tes chaines non
  20. alexis67
    alexis67 Member
    288Coins
    Je ne roule jamais les mains sous le siege donc pas de peur :)
