Linear Actuator Designs ...
Discussion in 'Motor actuators and drivers' started by speedy, Dec 27, 2013.
  1. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    @speedy (Any ideas making the Nut without 3d printing ?)
    You only need a drillpress that can drill on a angle.
    With plastic you can use a speed bore (for wood) to make the bearing places.
    You dont need to work precise ,with 3 bearings its centering when clamping
    Regards Ad
  2. DanielDk
    DanielDk Member
    386Coins
    NO :) That is just an example of what one may accomplish with a ballscrew and off the shelf parts.
    40$ is just the ballscrew and nut..
    For an acruator like that you need:
    a ballscrew and nut
    linear rails
    linear bearings
    motor coupling
    around 170$ when all is said and done...
    Heres pretty much all you need for an actuator like the one in the picture:
    http://www.ebay.com/itm/1-ballscrew...555?pt=LH_DefaultDomain_0&hash=item2a35ac3c7b
    Cheers
    Daniel
  3. bsft
    that makes more sense.
  4. Pit
    30,510Coins
    Very interesting. I wonder how the potentiometer could be placed. This linear concept needs an endless turn poti :)
    BTW 3 actators only $355...
  5. SeatTime
    I am using a 10 turn pot and suitably sized gearing. You could also use a rotary encoder, but I decided against this, due to the load it puts onto the ARD.
  6. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
  7. speedy
    Alexandria , Egypt
    7,948Coins
    @Pit @SeatTime For the pot there is an easy DIY way for wooden gear covered with a peace of timing belt ... super quit and can have a bearing in it's center feature .:thumbs
    This can be used for the 10 turn pot attached to it on one side ... and using another gear on the other end with a timing pulley running along and attached to the thread-less screw nut going back and forth along the Axis length ... turning the pot so exactly giving the precise position .
    • Useful Useful x 2
  8. speedy
    Alexandria , Egypt
    7,948Coins
    I've got another idea ... the same wooden timing pulley used above for the 10turn pot ... can be used running on a straight fixed half of the same timing belt along the motion rang ...
    both may be used as DIY "rack and pinion"
    edit: Plus ...a wooden planetary gears are available to use by this option ... for high torque and quite operation :thumbs
    http://woodgears.ca/gear_cutting/template.html
  9. SeatTime
    These are great ideas:thumbsunfortunately, I don't have the space in my new actuator to run a gear system beside the ball screw and with 80 turns end to end I need a 8:1 ratio, so the size of these timing belt gears would not fit nicely within my casing.
  10. speedy
    Alexandria , Egypt
    7,948Coins
    @SeatTime
  11. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    This will work to verry sheap.
    regards Ad
    153,980Coins
    +11,160 / 57 / -2
    Just a some suggestions.
    You can download the 3D print file for threadless ball screw here @speedy, if you want to give it a go: http://www.thingiverse.com/thing:112718
    And if you need a 3D printed part but do not own a printer then you could use the world wide directory of those who do and who can print a part for a small fee: https://www.3dhubs.com/
    You can also get a drill press pretty cheap these days if you know what you need and shop around.
  13. speedy
    Alexandria , Egypt
    7,948Coins
    @noorbeast ... Really cool :thumbs ... The issue with 3d printing is you wont get solid nut that can withstand the force and torque ... it may split and crack easily ... even if the print orientation changed ... it will just crack from another place .
    http://forums.reprap.org/read.php?14,328230,328627#msg-328627
    I just believe it can be made with these metal brackets ...
    And I keep turning my thoughts 70-80 degree to convert it from linear to circular and I fail to figure it out every time :grin
  14. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi speedy
    I hope this helps
    153,980Coins
    +11,160 / 57 / -2
    If splitting is the concern then machining rather than 3D printing would be the better option.
  16. speedy
    Alexandria , Egypt
    7,948Coins
    OMG ... Excellent big man .:thumbs
    I'm sorry my bad ... I didn't mention that it needs to be tilted a little so to engage with the threads like this
    and to give it an option to be used with threaded and thread-less rods like this one ...
    edit: I'm sorry I may be little speedy on questions ... but can we Angle Grind the locations which the steel corners will be bolted to ?
  17. speedy
    Alexandria , Egypt
    7,948Coins
  18. Pit
    30,510Coins
    just genius...
  19. speedy
    Alexandria , Egypt
    7,948Coins
  20. speedy
    Alexandria , Egypt
    7,948Coins
    Threadless Ball Screw Bench Speed and slip Test ... 5:45
