News 3dof linear acurator with steper motor 12Nm
Discussion in 'DIY Motion Simulator Projects' started by misoswan, Apr 8, 2015.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    Money is not a problem...... thanks
  2. SeatTime
    Ok then, all the best in your build.
  3. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
  4. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    this is big for my :) .....
    you're right project changed....I used linear actuator ( http://www.linak.dk/produkter/Linear-Actuators.aspx?product=LA36)
    like this https://simulatortech.wordpress.com/
    152,603Coins
    +11,087 / 56 / -2
    That site information was last updated in 2011. There is no video of the simulator in use under load. Are you aware if it was ever completed and tested?
  6. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    We will search for information.
  7. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I will seek to build linear actuator.Do you have any link.thanks
    152,603Coins
    +11,087 / 56 / -2
  9. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  10. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    152,603Coins
    +11,087 / 56 / -2
  12. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    yes . and for 3 x engine (https://www.motiondynamics.com.au/200w-dc-motor-12-24v-and-1600-3200-rpm-selectable-0.6nm-torque.ht) need 3 x JRK12? speak good? and , 3 X HP Proliant DL380 G4 Power Supply DPS-600PB B 321632-001 367238-001. ....Thank you for your help!
  13. SeatTime
  14. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    how much support the weight your old prototype?How fast?
  15. SeatTime
    I tested the single prototype actuator which used cheap commercial 200w - 3200 Rpm 0.6Nm motors to 24kg dead lift - using in-game inertia - so around 144kg lift capacity with six motors - OK for what I was building (carbon fibre Rig/I'm not a 'big' person). Speed with the direct drive commercial 200w/3200 rpm motors and 5mm lead ballscrew = 260 linear mm per Sec. The design has changed a bit since then both mechanically and the electronics, with the capability to fit practically any motor/gear combination - for more weight/speed design possibilities. I'm also testing different feedback methods - rotary encoders etc and motor controllers/drivers. Eg. Just some of the motor controller/driver stuff that I am playing with - see below. Unfortunately like I said, it is still a work in progress, which I have to fit between all the other things that I do.
  16. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    witch motor would you say is best for me to buy .so the linear acturator lift 90kg.
  17. SeatTime
    I have not tested anything that big yet in regards to a sim, so I will leave for others to advise.
  18. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    152,603Coins
    +11,087 / 56 / -2
    It is hard to make a recommendation without a clear design. Have you got a more detailed plan you can post?
  20. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    looking items to maintain a 100 kg matter if it is a linear actuator or DC Geared Motor Worm Drive .my idea is that it was not big. 3dof
