Tutorial Mjoy16 USB AVR Joystick
Discussion in 'DIY peripherals' started by tronicgr, Jan 3, 2008.
  1. Evais Zar
    Evais Zar New Member
    Islamabad, Pakistan
    199Coins
    2DOF, 3DOF, DC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT
    Thanx Thanos
    I will try to change their names and will test it...
    Owais
  2. Darkhanbaatar
    Darkhanbaatar New Member
    - 6Coins
    2DOF, DC motor, Arduino, 4DOF
    hi all i have problem and i builded Mjoy8 but usb error is unknown device how i repair it and i already readed all comment and i burned to atmega by minipro TL866CS. sorry my english not good
  3. Darkhanbaatar
    - 6Coins
    hi
    I builded that circuit but didn,t work, i used 3.3v zener and i burned hex file to atmega by MiniPRO programmer i didn't use ponyprog, what i do now?
  4. Pixello
    Pixello New Member
    Student, Amateur designer and programmer
    Krosno
    449Coins
    3DOF, DC motor
    Check fuse bits, 0xCF HIGH and 0xFF low should work well. Also i have reprojected PCB (by mi), as small as it can be :D I'm including PDF and eagle PCB files :D. Note that analog GND should be separatly connected to main GND by chooke
  5. Darkhanbaatar
    - 6Coins
  6. Pixello
    Pixello New Member
    Krosno
    449Coins
    3DOF, DC motor
    Chceck zener diodes and resistors at usb data lines, i looked at picture, mjoy 16 remains Atmega16/Atmega16A, set cokpt fusebit (0). Lets try my version of pbc, 1 link up, its smaller and it work at 100% :D
  7. steve50
    steve50 New Member
    558Coins
    DC motor
    Hi!
    For Mjoy16 you have to use a Zener diode 3.3Volt, 0.5Watt, not higher Watts! Earlier I biult an MJoy16, very accuratly, but it did not work, "Not recognised"... The only problem was:I used 2Watts zener!!! I changed it (all 2 of them :) ) and now it works fine!
  8. Darkhanbaatar
    - 6Coins
    Mjoy don't work, i checked Zener my used 3.3V zener and i changed 3.6v zener, result is same what we do now
  9. Sokol1
    Sokol1 Member
    14Coins
    FYI - Since Mjoy/Mjoy16 is now obsolete (USB 1.1 - low frequency), a cheap Arduino PRO micro provide a better solution (USB 2.0, high frequency).
    Firmware for joystick already available, the Mega_Mozg MMjoy: http://simhq.com/forum/ubbthreads.php/topics/3899105/MMJoy_-_Build_your_own_USB_con
    Is not cost effective - besides difficult due the SMD format of ATMEGA32U4 - but PCB layout for DIY assembly is available.
  10. Al T
    Al T New Member Gold Contributor
    172Coins
    Motion platform
    Guys, could you please have a look into my project and share your ideas how to integrate joystick into this machine?
