Hi there. So interesting forum you got here, that I had to do my own 2 DOF Full frame in stainless
Discussion in 'DIY Motion Simulator Projects' started by Ken50, Mar 29, 2015.
  1. bsft
    Nice job on the welding, however, Id suggest some more steel to stiffen the back up
    Dave.
  2. Nick Moxley
    Part reason i suggest these style Vs the Normal style.
    Greased joint with a Rubber boot and offer's Far more "travel" on the joint itself.
    http://www.aliexpress.com/item/4pcs...ight-hand-tie-rod-end-bearing/1559309095.html
  3. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
  4. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    I'm aware of this little problem, thanks to the nice forums you got in here! Have already made the nuts conical on each side, helps alot!
  5. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Do anyone have any experience with these motors:
  6. SeatTime
    Just for interest, are you using a TIG?
  7. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Right you are!
    153,950Coins
    +11,159 / 57 / -2
  9. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Oh,didn't no you had one, silly me!Well, I have ordered the one's with the 25:1 Ratio.
    153,950Coins
    +11,159 / 57 / -2
    No problem.
    Do poke around the FAQ section, there is some really handy info there when you are building a sim, from ideas to solutions.
  11. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    I did what you said, not so big though, have to think about the weight! But as you maybe can see on the picture, I have also mounted a bolt and a rubber spacer further up on the back, into the seat.Now it's stiff!
  12. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    A little progress!
  13. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    Nice progress @Ken50.
    What motors, control boards and PSUs do you plan to use?
  14. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Motors ordered ,the crap pot one's from EBay with the 1:25 Ratio
    Pololu Jrk 12v12
    2 x server PSU 575W 47A
  15. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    As you can see I choose to make it adjustable.
  16. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
  17. bsft
    what are you making adjustable? for shorter drivers?
  18. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Or longer,yes.I know I will move the 0-point, but it will only be for a little while, and I'm sure the motors can take it. I don't mind people trying my rig.But not too long, though!
  19. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    I have a son and he's almost 2 meters high, and I'm (only) 188cm,and a stepdaughter (12y)who is begging me all the time. But if it will ruin my stiffness, it will be welded up at no time!!!
  20. bsft
    Balance it for heavier driver, and make pedals and wheel adjustable. Keep the balance point in one place.
