Tutorial From AtoZ : 2DOF arduino wiper playseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 8, 2013.
  1. frenchfly
    frenchfly Member Gold Contributor
    Mold Maker
    Winnipeg, Canada
    - 296Coins
    2DOF, JRK
    Not wanting your rig to sag when the motors stop has nothing to do with OCD if that's what your referring to.
  2. bsft
    I know, I am being a bit cheeky. I still think is aesthetics related though, and you are taking away finer motion and or trying to compensate for improper design.
  3. frenchfly
    Mold Maker
    Winnipeg, Canada
    - 296Coins
    2DOF, JRK
    I'm perfectly happy with my finer motions as well as my design. But I know based on the many threads I have read you tend to be critical of wiper motors:) I may try the bigger motors in the future but these have been bullet proof from day one. Some wiper motors are better than other, more so when they are new. I did go with the JRK's though based on your recommendation.
  4. bsft
    Wipers are fine, I used them on several sims at the beginning. But I wanted more, hence I tried and tested the larger motors with success. I am not against wipers, I only suggest something more powerful, thats all.
    Like suggesting a JRK over an arduino - hbridge set up. Might cost more, but easier to set up for noobs like me.
  5. dualclick
    dualclick
  6. bsft
  7. Matth.Gyver
    Matth.Gyver New Member
    208Coins
    Thank's for this detailed tutorial ;-)
  8. RacingMat
    20,894Coins
    You're welcome Matth.Gyver :)
    Please take time to present yourself in the New Member thread http://www.xsimulator.net/community/posts/62442/
    you can pinpoint your location on the member map as well! I'm always glad to see how far my tutorial has travelled...
    and tell us what is your simulator dream!!
  9. Matth.Gyver
    208Coins
    It's done ;-)
  10. wallytattoo
    wallytattoo New Member
    383Coins
    Hi all, where under the .ino code to load, can anyone help me, I'm new and I'm starting, so much I do not understand. Well I hope you can help me. a hug
  11. RacingMat
    20,894Coins
    Hello! Have a look in the Resources in my signature ;-)
    What is your Hbridge model?
  12. wallytattoo
    383Coins
    Hi, I have the shield motomonster DEV-10182 .
  13. RacingMat
    20,894Coins
  14. Alexandre Kostik
    Alexandre Kostik Member
    realtor
    Brasil
    422Coins
    Hello @RacingMat !!! I am doing a 2dof based on your code and assembly. I used to ride this prototype materials he had at home and used parts store . After testing and work, do my final chassis. I made my bridge h , according to the attached wiring diagram and a logic circuit to connect the PWM signals , with direction signs on Arduino outputs. It's working , but the motors move as if they were fighting ... even when I trigger the output testing .... you can see in the video. My pots are cheap because they do not meet the ceramic here in Brazil ... what may be the cause of non- slip soft motor movements ? Thank you and sorry for my english ... google translator.
  15. Alexandre Kostik
    realtor
    Brasil
    422Coins
    another video of engines and engine game
  16. RacingMat
    20,894Coins
    yours vids are private: you have to change their status
  17. Alexandre Kostik
    realtor
    Brasil
    422Coins
  18. RacingMat
    20,894Coins
    I had a quick look: sliders have a good effect on motors!
    the shaky movement may be due to:
    - bad pot (as you said)
    - bad mechanical link between pot and motor
    - not shielded wires
    - bad soldering
  19. Alexandre Kostik
    realtor
    Brasil
    422Coins
  20. RacingMat
    20,894Coins
    @vthinsel
    some pictures for dimensions
    dimensions 2DOF (14).JPG dimensions 2DOF (3).JPG dimensions 2DOF (2).JPG dimensions 2DOF (1).JPG dimensions 2DOF (6).JPG dimensions 2DOF (7).JPG dimensions 2DOF (4).JPG dimensions 2DOF (5).JPG dimensions 2DOF (11).JPG dimensions 2DOF (10).JPG dimensions 2DOF (9).JPG dimensions 2DOF (8).JPG dimensions 2DOF (13).JPG dimensions 2DOF (12).JPG
    it's a kind of brainteaser chinese-puzzle but if you take your time, I hope you could find all you need!
