4 Axis Simulator with an obutto r3volution
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Anton60400, Dec 27, 2014.
  1. Anton60400
    Anton60400 Starter
    beginner of Software Developing
    Hannover, Germany
    374Coins
    2DOF, DC motor, JRK, SimforceGT
    Hi, how can i build a 4 axis motion simulator with my Obutto R3volution.my idea was to stick a motor to every side but i don't know how to control this thing and if it will work.
    thanks.
  2. bsft
    4 axis as in full lift?
    Maybe a tad tricky depending on how much weight you are and whats going to sit on the frame.
    I would suggest a 2 DOF balanced pivot point under the full frame and either shoulder mount motors at rear or foot motor mount them.
    Full lift frame setups can get expensive as you require powerful motors to lift the whole thing.
    • Dislike Dislike x 1
  3. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    so i mount the motors like in the drivingforce gt preset?
  4. bsft
    pardon? what are you trying to achieve?
    The motors get hooked up to controllers and riven off Simtools
  5. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    i mean that the motors move the back of the obutto r3volution at 2 points
  6. bsft
    shoulder mount at rear, yes
  7. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    and with 4 motors i should mount them where the wheels normally would be right?
  8. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    can i use pistons with air instead?
  9. bsft
    Could you draw up a sketch of how you might want to set it up please?
    Air pistons, I am not sure if there is an actual wiring setup, I think you would need a K8055, custom code to be written, air valves, etc.
  10. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    well i am not that much into coding:think
  11. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    is there a way to build like pistons with motors inside?
  12. bsft
  13. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    well the obutto is ordered but still not arrived. i can draw how i want everything to be.
  14. bsft
    yep, that will do , or use existing photos off the net and draw lines indicating what you would like to do
    153,866Coins
    +11,152 / 57 / -2
    • Informative Informative x 3
  16. Anton60400
    Anton60400 Starter
    Hannover, Germany
    374Coins
    that is my idea of doing it with pistons. and i want to replace the pistons with like motor pistons kind of.
  17. bsft
  18. SeatTime
    What is your budget? Those Obutto frames can be heavy.
  19. Alejandro Luevano
    Alejandro Luevano New Member
    646Coins
    Motion platform
