SimTools Presets SCN5 iRacing 2 axis 5dof
Discussion in 'Game Engine axes presets' started by Rinus janssens, May 7, 2014.
  1. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Axis files for iRacing 64bit.
    I uploaded my axis assignment file, axis config file and MinMax file just to try and see if this works with other SCN5 users.
    The length of the actuators doesn't matter because Simtools autoreconice the length of them.
    The max actuator length is set on 95%
    The settings in game manager can be set to your taste and are untouched.
    The setting are premature and not finished and maybe they need some tweaking.
    Maybe this will help people to get started.
    Place and unpack the AxesConfig.cfg file in C:\Users\your name\AppData\Local\SimTools\GameEngine\AxesPresets map.
    Place and unpack the AxisAssignments.cfg in C:\Users\Your Name\AppData\Local\SimTools\GameEngine\Config map.
    Place and unpack the Min Max file in C:\Users\Your Name\AppData\Local\SimTools\GameEngine\MaxMinProfiles map.
    iRacing 64bit Axes Config
    iRacing 64bits Axis Assignments
    iRacing MaxMin file
    If there is a easier way to share these setting please let me know ?
  2. Rinus janssens
    Holland
    2,153Coins
    SCN5
    I updated the MaxMin file after latest iRacing plugin
  3. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    where to load these files? thx
  4. Rinus janssens
    Holland
    2,153Coins
    SCN5
  5. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello, is appdata hidden directory ?
    i can t see it neither in game pc nor engine pc
    thx
  6. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    AppData could very well be hidden - and you'll have to go to the "Folders Options" and tell it to "show hidden files and folders".....
    It's located in the root of C:\
    Tom
  7. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    i run 2 pcs. Is it in the gaming pc (primary) or engine PC (secondary)
    thanks
  8. Rinus janssens
    Holland
    2,153Coins
    SCN5
    Its where game engine is installed ? I think lol
  9. Benjamin K.
    Benjamin K. New Member
    Germany, NRW, Plettenberg
    363Coins
    You can Type %appdata% in the Searchfield of Your Windows Start Menu.
    It will open the Roaming Folder located in AppData.
    Go one Folder Up and you see the "Local" Folder that should contain Simtools.
  10. sjmy
    sjmy i like a wind
    china
    194Coins
    2DOF, SCN5
    so good ,3Q
