2dof to 3dof DIY Seat mover
Discussion in 'DIY Motion Simulator Projects' started by Nick Moxley, Mar 3, 2014.
  1. Nick Moxley
    Alright, New Project time.
    Hard mount
    Thin Foam
    Thick Foam
    • Creative Creative x 2
  2. bsft
    I just fart harder
  3. Nick Moxley
    Classic dave question/answer. :grin
  4. Nick Moxley
    Well here she is, Completely Overkill on the project but hey, what the point of a project if your just going to hack it together and make it look like crap.
    Baffles were Dadoed into place but were unfortunately a little loose, So Good ol Wood glue to the rescue.
    Figuring out the corner's with the foam.
    base foam
    80x80 fans will be mounted to either end plate and One will Suck and One will Blow....Ill be finishing That up today when i return the 200mm Fan I attempted to use(Way too low of CFM)
    153,950Coins
    +11,160 / 57 / -2
  6. BlazinH
    16,691Coins
    Looks good what ever it is! :cool: (I must have missed something from awhile back)
  7. Al.Bundy
    Al.Bundy Member
    mechanic
    belgium
    682Coins
    Is it a subwoofer ? Or a buttkicker maybe ?
  8. bsft
    Yes, what is it?
  9. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    i think it is an air compressor in a DIY silencer box
  10. bsft
    self contained nuclear reactor for powering the motors
    • Funny Funny x 3
  11. Nick Moxley
    Correct Insane. Its a Air pump enclosed in a sound proof box. Pump is for the Ekretz mod on my Fanatec CSW. M000000re POWER!!!!!
    This Box will also double as a stand for this Bad boy.
    Fan's mounted Tested a Work Freaking awesome,
    Intake 120mm fan is 2000rpm and 70 CFM
    Exhaust is 80mm is also 2000rpm but only 31cfm
  12. bsft
    now I am really confused
  13. Nick Moxley
    What Troubles you buddy ? :p
  14. bsft
    what is it?
  15. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    @bsft - He is going to change his motor from Fanatec CSW wheel with bigger and better one (Buhler motor) and once he meets it's force he would need to cool it better than the current stock fan inside Fanatec.
    Therefore the nuclear reactor ;)
  16. bsft
    Thanks, Nick told me via skype. I still have no idea how it works, I will try to look up example later.
  17. Nick Moxley
    I haven't ran the Air line yet, so that might not help seeing the end product and what its for. But ya. All thats left is to wrap it in some carpet, Drill a hole for the 1/4" tubing and power to come out and wire up a 12v supply for the fans. Then just wait for the motor's and Mod parts......... Then take apart the wheel and go to the machinist buddy and go to Town Lightening Everything we can to reduce the Free wheel friction as Much as possible......Then Install a Slip Ring like this to again aid in removing the friction...>Then im sure ill find more stuff to do.......lol
  18. Nick Moxley
    Maybe this will help, Air Passages into motor's
  19. bsft
    ah, copy that!
  20. prodigy
    Croatia
    6,698Coins
    @Nick Moxley
    Great to see detailed work about that mod, I'm impatient to see the final stuff and your impressions how it feels comparing to stock CSW.
    Did Ekretz sent you all the required parts for you to do it alone or does he also takes the customers wheel and do the mod himself?
