value1
Euro Truck Simulator 2 Plugin 2.0.2.2
SimTools game plugin for Euro Truck Simulator 2
  1. darkmold9
    darkmold9 New Member Gold Contributor
    Québec, Canada
    53Coins
    3DOF, Arduino
    Hi Historiker, did you do something special to make it run? I have Windows 7 64bit and cant get it to run. I have a steam version of the sim. Tried LFS and works just fine. But eurotruck just dont want to work. Axis Assignment same as LFS but for Euro truck simulator 2 in Game List, clicked Save Settings, Interface Settings Presets set to SimAxe , Output Type SER and clicked Save. Game Manager says Game running in blue and Game Engine Virtual Axis are turned On but nada nothing is moving!
    My installation folder is not on C: drive but plugin is intalled in my installation folder anyway.
    I need to get that game running ...
    Thank for your help.
    • Optimistic Optimistic x 1
  2. mugge66
    mugge66 Member
    Denmark near Copenhagen
    167Coins
    2DOF, JRK
    I have the exact same problem, did you find a solution ?
  3. value1
    14,504Coins
    Hi @mugge66
    This might help:
    Exit the game.
    Delete the file "SimTools_ETS2.dll" in directory ..\Steam\SteamApps\common\Euro Truck Simulator 2\bin\win_x86\Plugins" (and maybe all other files in the directory too).
    Unpatch the game in GameManager
    Patch the game in GameManager.
    Start the game
    If it worked there will be a message like this during startup:
    Let me know if it worked, please.
  4. berty
    berty Member
    164Coins
    And when I do not have steam and also it does not work? You do not know what to do?
  5. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    I have done that but it doesnt help, I do get that message and my simulator is calibration at startup. but when playing game i get no motion. In tuningcenter there are no action.
  6. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Did a new install from steam, it works in a way. As you can see on game data nothing shows, but when i do a new capture this shows up. and yes there are movement in game but it´s complete out of control.
    The simulator is moving me in all directions without any control.
  7. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Funny
    Even if my main level is at Zero i still get alot of movement
  8. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Dont understand this, There has be something odd with this plugin. I have Surge witch have very slow reaction, and sway witch seems to make the simu move left and right in some uncontrolled movement.
    Do anyone else have these issues. my Tuning center still not shows any action. ive been playing around with different settings and what is wierd is
    iracing /ac / rfactor works perfect. ?? i only have these problems with eurotruck
  9. yobuddy
    48,195Coins
    The main level% smooth's the output to the simulator. (basically meant as a quick for a kids ride etc..)
    It will still move around, but with it all turned down like you have it, it will be very slow and won't match the output cues from the game.
    Set it back to 100 for the most accurate ride!
  10. ericRacer
    Pilot
    Canada, Quebec
    989Coins
    any solution here ? i have the same problem -> no motion , no numbers in the tuning center !:think
  11. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    i never got mine to run properly.
  12. value1
    14,504Coins
  13. noorbeast
    145,112Coins
    +10,778 / 52 / -2
    Nice one @value1, I will be able to give it a 64 bit go...after trying the updated Nolimts 2...after War Thunder...after Star Citizen...I just can't keep up ;)
  14. antonio_199
    antonio_199 New Member
    Vera, Spain
    198Coins
  15. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    Anyone got it going? Tried everything... older versions x86, new x64 admin access, nothing works.
  16. noorbeast
    145,112Coins
    +10,778 / 52 / -2
    Still on my todo list @Radek vols. I am a bit snowed under with work but if I can I will give it a try sometime soon.
  17. value1
    14,504Coins
    It runs fine here.
    Please check, if there is a file SimTools_ETS2x64.dll in C:\…\Steam\SteamApps\common\Euro Truck Simulator 2\bin\win_x64\Plugins and/or SimTools_ETS2.dll in C:\…\Steam\SteamApps\common\Euro Truck Simulator 2\bin\win_x86\Plugins.
  18. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    Yes I also tried deleting them unpatching and patching again as you said before. And still nothing. LFS, Rfactor is working great but ETS2 write SDK feature detected but it show nothing on virtual axis or Dashboard
  19. value1
    14,504Coins
    Good start.
    Have you tried fiddling with the Max/Min values in Tuning centre? These values are probably too high. Please check:
    TuningCentre.gif [/quote]
  20. value1
    14,504Coins
    Also: Check, if there is something wrong with your Axis Assignments for ETS2:
