MRAP Seat Mover - first motion
Discussion in 'DIY Motion Simulator Projects' started by RufusDufus, Jul 22, 2013.
  1. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,258Coins
    Thanks for your comments :cheers
    No, the rope is actually connected to the main drive pulley so it can't slip. The downside of this is that it limits the number of turns that the pulley can turn to the number of times the rope is wrapped around the pulley. I have the rope wrapped twice around a 40mm pulley so I can get 40 * pi * 2 = 251mm max travel although I currently only drive it about 120mm travel max - any more gets too wild in my setup.
    On the other side of the motor I connect the feedback POT to the Motor using two other pulleys and some string as a belt. This is not connected to the pulley but I have not had to make any adjustments during the time it has been running. The string seems to grip on the MDF pulley really well - and of course the POT doesn't create much load so it doesn't seem to slip. If you used plastic or metal pulleys this may be a problem?
  2. RufusDufus
    Adelaide Australia
    16,258Coins
    Finally getting round to adding a video...
  3. Pit
    30,490Coins
    Great work! Where is the cat?:)
  4. BjornG
    BjornG New Member
    Mechanical Engineer
    USA
    327Coins
    awesome, a mine resistant ambush protected sim I was expecting .. it does have the right tan color thou .. :)
    Very cool.
  5. RufusDufus
    Adelaide Australia
    16,258Coins
    Haha good pickup... she's a very friendly cat and would have been close by somewhere.
    Here are a couple more videos...
  6. fry82
    fry82 New Member
    452Coins
    Clever design, really like it....... I'm only new, and haven't seen a design like this. Impressed.
  7. bsft
    he has plans as a PDF file on the first page of the thread as well.
  8. fzxj520
    fzxj520 Active Member
    1,341Coins
    Very cool!do not take the unusual way 。Linear actuators!
