First attempt at a 2DOF motion sim
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Jul 24, 2014.
  1. SilentChill
    20,596Coins
    Hi all, just wondering if these parts I'm about to order are going to be any good. They don't have to last all that long as I will be upgrading once I get to grips with things just want to do it as cheap as possible for now.
    4x http://www.ebay.co.uk/itm/141353558028
    2x http://www.ebay.co.uk/itm/331220546114
    http://www.ebay.co.uk/itm/141306525371
    http://www.ebay.co.uk/itm/161262305272
    http://www.ebay.co.uk/itm/251060570083
    http://www.screwfix.com/p/bzp-threaded-rod-m12-x-1000mm-pack-of-5/98942
    A few other bits to get like a cheap arc welder and scrapyard driveshaft.
    Thanks for looking,
    Cheers,
    Craig.
  2. eaorobbie
    20,489Coins
    All looks good Craig. @SilentChill , just beware the wiper will need modification as they run the earth through the body of the wiper so this will be needed to be removed before using for a simulator. Or when the motor goes in reverse it will send 12Vs running the through the frame and anything like a set of pedals even the Ard (through the pot connections) will get a back 12v shock , normally frying them good.
    Next I would find some pipe to sleeve over the M12 All Thread , tends to bend with sharp motion changes (done that one myself- ah what!!) so a sleeve over it will help it immensely.
    Apart from that mate all looks good, would recommend you look into @RufusDufus code , a very nice app that makes it easier to setup, a few now have used this now successfully with all the same components you propose.
    Happy Building.
  3. SilentChill
    20,596Coins
    Awesome thanks @eaorobbie I've just hit the purchase button just need to go to the scrappy and get some metal and ermm metal things lol.
    Let's see how this goes :eek: Rock on !
    Cheers,
    Craig.
  4. SilentChill
    20,596Coins
  5. eaorobbie
    20,489Coins
    Ok
    1. Fuse box can be handy but not a real need on 12v sim but for the extra protection , cool.
    2. Pots I would use 360 deg pots cause when setting up, you may get a setting wrong , etc and the lever will spin all the way around, but depending on how you mount them will depend whether they survive or get twisted into 2 separate parts. But the ones you have choose will still work just an in built stopper or different connection to stop the pot from being destroyed easily is recommend for use on a Ard setup.
    3. Base shackers sorry cant comment , never found the need to use them.
    4. Emergency switch , that's a must plus can be handy for isolation purposes,
    I use mine as safety switch plus I use it to turn off the JRK12v12 when I hope off the sim for a little rest but don't want to power every thing down, for example hit the switch the drivers shutdown and when I jump back in ,open the switch and it all comes to life, while SimTools is still running in background, another handy point is for testing , ie motor goes made , one click all stops instantly.
    Hope that helps.
  6. SilentChill
    20,596Coins
    Thanks again @eaorobbie , about the pot, I picked a 1 turn one as that's what everyone was recommending does 1 turn = 360 ? Or am I being dumb lol
  7. bsft
    there are single turn 270 deg rotation pots and single turn 360 deg rotation pots.
    He is referring to the 360 deg rotation pots .
  8. SilentChill
    20,596Coins
    Ok thanks @bsft , think the ones i have chosen are 340deg from what i can tell from the details i will have to try and just attach them properly so i dont split them.
  9. mugge66
    mugge66 Member
    Denmark near Copenhagen
    167Coins
    2DOF, JRK
    Hi
    when mounting the threaded 12mm rods to these a good idea is to put some grease on the thread and also a mount an extra nut, i did the same and it took away some cranking sounds. Will post a picture later. :)
  10. SilentChill
    20,596Coins
    Thanks for the tip I'll make sure I do it. Most of my stuff should be arriving this week so I should be able to get it hooked up and see if it works ok.
    Just need to get a cheap welder bought and make a trip to the scrapyard get some more bits.
  11. SilentChill
    20,596Coins
    Ooooo exciting stuff has arrived lol :oops:
    Picked the UJ from a local scrappy only cost me 5 squids :thumbs
  12. SilentChill
    20,596Coins
    Just got a brand new arc welder for 30 bats ! Gotta love eBay ,Happy dayz . I have time now before the welder comes to get everything wired up and see if I can get my head round what I'm suppose to be doing .
    Then just need to practice welding a few things lol
  13. bsft
    squids? bats? what currency are you using?
    • Funny Funny x 3
  14. SilentChill
    20,596Coins
    Haha yes around here we still trade with many things, can get a lot for a pint o grog that's liquid gold
    152,700Coins
    +11,091 / 56 / -2
    I am looking forward to following your new build.
  16. SilentChill
    20,596Coins
    Thanks ill try and put plenty of updates and photos on as I go
  17. SilentChill
    20,596Coins
    Let's get soldering
  18. SilentChill
    20,596Coins
    Just a quick update, I built the SIM out of wood just to test everything whilst ibwaited for my welder to come . Just as well as my motomonster was dead on the second motor forts motor worked fine. Should have a new one tomorroowow
  19. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Check everything! Take nothing for granted! :thumbs
  20. SilentChill
    20,596Coins
    I seriously need to watch more YouTube vids on how to weld, seems it's a bit harder than siliconing round a window frame Lolol
