Right motor not communicating with simtools output testing
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by cyberxu, Jun 23, 2014.
  1. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Hello Sim builders,
    I managed to manually turning my L & R pots to move L & R motors, Arduino code works fine thanks to RacingMat.
    Problem start here, I attached my pots to the motors, uploaded preset cfg for axises and interface cfg. while get to output testing my motors, I managed to move L motor by sliding the slider with mouse. Its actually gives my max , center & min movement too. Even Roll, Pitch & surge are working for left motor while output testing.
    NOT my Right motor. no movement at all.??? Just to double check my pots is still works, so I turn off the output testing, turn my Right pots and sure enough Right Motor moves.
    I thought I threw this issue out there to see if anyone had this or seen this problem before? Perhaps getting some help or advise from you experts out there.
    here are my setting:
  2. yobuddy
    50,785Coins
    You have a space in <Axis 2> - should be <Axis2>
    Let me know if it worked?
    edit: looks like you have a space in <Axis 1> also, please remove the spaces.
    Let me know how it goes buddy!
  3. RacingMat
    21,042Coins
    What a sharp eye @yobuddy! :thumbs
    @cyberxu : as I told you, you should have used the presets I uploaded... :confused:
  4. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Sorry, I posted the wrong pictures earlier! I did upload your presets!
  5. RacingMat
    21,042Coins
    I don't find any explanation at the moment?!
    I've sent back the 2x12 (too weak for the smolka) and I'll receive the 2x25 tomorrow:
    i'll redo the wiring and check again!:)
  6. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Came home from work and quickly confirm that these are my settings using RacingMat presets. Tried output testing it again ...same result! Motor R not responding! Only manually turning pot is working!
  7. RacingMat
    21,042Coins
    please refer to the next step after manuel pot turning: http://www.xsimulator.net/community...dof-and-1-pwmpin-1-dirpin-hbridge-board.4614/
    - use serial monitor!
    can you make the right motor moving with serial monitor?
  8. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Hello Mat,
    I tried using serial monitor to send order and I managed to get the right motor to respond. I basically tried all the hex orders from your link you posted.....:)
    So I guess its a good thing!
    tried the output again ...no luck!
    Cyberxu
  9. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Hi Mat,
    new discovery, I changed my interface setting (see pic). I got the R motor to move and now the left motor stayed still.
    its totally opposite of the original problem.
  10. RacingMat
    21,042Coins
    Oh... I'll test that with my 2x25 I just received.
    Maybe I have to correct something in the code...
  11. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    I have my motors mounted in the front of the seat. so I remembered reading somewhere in your link that if I need to reverse my rotation the motor turns, just reverse the motor wires. I tried it last night on my left motor and it went crazy. it started from center position of the arm to opposite (180 deg) turn and start jittering. Is it something to do with the code too?
  12. RacingMat
    21,042Coins
    You cannot reverse motor supply wiring without reversing your pot wiring!... :confused: you're a sorcerer's apprentice
    Once step 1 achieved, you should use Simtools reverse function "Dir" in Axis assignments!
    I wrote a basic test code to test your right and left motor: have a try and tell if both are running.
    Code:
    test
    #include <SabertoothSimplified.h>
    #include <SoftwareSerial.h>
    SoftwareSerial SWSerial(NOT_A_PIN, 8); //declare the Pin 8 to be used to communicate with Sabertooth
    SabertoothSimplified ST(SWSerial); //open a serial COM on previously identified pin
    void setup()
      // serial initialization
       SWSerial.begin(38400); // serial between Arduino and Sabertooth on SWSerial pin
      //DIP switches 2, 4 and 5 OFF
      // stop motors at startup
      ST.motor(1, 0);
      ST.motor(2, 0);
      // tests
      test(1);
      test(2);
    void test(int motors)
      int power;
      // Ramp from 0 to 127 (full forward)
      for (power = 0; power <= 127; power ++)
        ST.motor(motors, power);
        delay(20);
      // Now go back to full reverse
      for (power = 127; power >= -127; power --)
        delay(20);
      //Ramp down to stop
      for (power = -127; power <= 0; power ++)
        delay(20);
    void loop()
  13. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    yes Master...apprentice I am .....:p
    Try this code I will!:grin
    • Funny Funny x 2
  14. RacingMat
    21,042Coins
    Now understand I, why yoda old was looking!...
  15. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Master... I tested your basic code and it's good.
  16. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    MaT,
    Have you tried it(code) on your new 2X25? Does it come out the same result as what I experienced?
    I ran out of ideas......I am at complete road block again!
    Cyberxu
  17. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    This Arduino Uno and Sabertooth 2X12 combination are giving me headache! Can anybody suggest a better combination that I can save $$$?
  18. eaorobbie
    20,475Coins
    Mat will sort this, Im sure.
    • Optimistic Optimistic x 1
  19. cyberxu
    cyberxu Member
    AME Planner
    Ontario, Canada
    516Coins
    Thanks eaorobbie! How's the testing coming along with K8055N?
  20. RacingMat
    21,042Coins
    Thanks for your optimism!
    I haven't found yet the problem...I'll do more test this week-end
