  1. Brighton
    Brighton Member
    221Coins
    DC motor
    Ok thanks. Hey is any how for people who making,working on simtools that they can put more plugsin for more interfaces like k8055 works very good for 2 axis. Thanks guys
  2. mario73
    mario73 New Member
    Mecchanik
    Monza
    382Coins
    DC motor
    thanks for the reply i use a type s load cell and it work for 0 to 100kg ,my brake pedal is equipped with adjusting screw to adjust the hardness, but I can not determine exactly how many kg. for this I thought to display them on a display.
    now to run my pedals use the buo836lc, it would be possible to use arduino (or other card that gives me the ability to view kg or on a display or directly in the settings-gaming of windows) to interface my pedal board to the PC? in order to be seen by rfactor
  3. Historiker
    9,208Coins
    Hey Brighton, you can also pick up a cheap Arduino UNO to control your drivers. Prilad and RacingMat have both posted codes to interface the Arduino with Simtools.
  4. wlkb
    wlkb New Member
    268Coins
    2DOF, SCN5
    I come from Taiwan
  5. Brighton
    Brighton Member
    221Coins
    DC motor
    cool thanks, is any how we can get the plugin for K8055? Is very good if you using 2 axis. thanks.
  6. bsft
    looks like several people have answered your question. granted you have a K8055, but I think its not planned for support. it has proven itself slow, unless you can prove us wrong.
    Arduino or kangaroo would be the next step.
  7. Brighton
    Brighton Member
    221Coins
    DC motor
    cool thanks, i am gonna try to use the Kangaroo
  8. eaorobbie
    20,489Coins
    To drive a sabertooth i wouldnt use anything else mate, let us know if you need a hand.
  9. Brighton
    Brighton Member
    221Coins
    DC motor
    Hi, is the pololu jrk 12v12 can drive my 24v wheelchair motor?? If not what else i can use to drive two 24v 5A wheelchair motors that it have plungin in simtools. Thanks guys
  10. Brighton
    Brighton Member
    221Coins
    DC motor
    Hi, is the pololu jrk 12v12 can drive my 24v wheelchair motor?? If not what else i can use to drive two 24v 5A wheelchair motors that it have plungin in simtools. Thanks guys (except arduino )
  11. eaorobbie
    20,489Coins
    For serial devices in sim tools we dont use plugins ,we can set the com port setting and send command packets as needed.
    For driving 24v devices is a step up from what a jrk can do. A Sabertooth 2x12
    http://www.dimensionengineering.com/products/sabertooth2x12 which is capable of driving 24v easily at the amps you require.
    Now this can be connected via a Kangaroo x2
    http://www.dimensionengineering.com/products/kangaroo
    And can be wire simularly to the PDF contained.
    http://www.dimensionengineering.com/datasheets/KangarooPackInInstructions.pdf
    This driver has not been tested but to venture into 24v territory you need to test, plenty of help here to
    guide you along, I actually have a Kangaroo with Usb Adapter which they provided for free, Just awaiting to
    purchase a Sabertooth to test with myself.
    Sorry from post above , inquiring about K8055 thought you had a system already running the driver.
    My apologizes.
  12. bsft
    no, 12v motors only
  13. bsft
    kangaroo or ard.
  14. Brighton
    Brighton Member
    221Coins
    DC motor
    @eaorobbie, Thank you so much for all the info.
    I have Sabertooth 2x12 i am gonna get the kangaroo and i will test them. Thanks
    One more Question; when i will connect the sabertooth 2x12 and kangaroo together with Usb Adapter, in the Game engine interface options what i am gonna choose? i can only see in output USO: JKR 12bit,
    JKR 7bit
    JRK 12bit
    JRK 7bit
    SIM axe
  15. Brighton
    Brighton Member
    221Coins
    DC motor
    Thnks @bsft
  16. eaorobbie
    20,489Coins
    Ok Brighton time to start your own post on a sim build or motor control and we can continue.
    In reply we need to set a custom serial command as described in the DE manual for there software. Sim Tools allows us to do this.
  17. eaorobbie
    20,489Coins
    Welcome Wlkb.
  18. Mario Reinecke
    Mario Reinecke New Member
    Kassel Germany
    587Coins
    back again,
    now i´ve got a brand new 75Ah carbattery, 3 Polulus and 3 VW wipermotors.
    What i now need is a connectionplan.
    1. Can i try to place the wipermotors isolated? means the wipermotors dont come in touch with other peripherals?
    (so i dont need to isolate earth ?)
    2. I´ll try to use a strut bearing instead of a universal joint for the seat. Maybe i got a little damper effect using this..
  19. bsft
    Hello Mario , as best you start your own thread as well so we can discuss it more.
  20. Cristian
    Cristian Xsimulador
    Argentina Bs As
    234Coins
    2DOF, Arduino, Joyrider, SimforceGT, Motion platform
    Hola amigos soy de Argentina y estoy contruyendo mi simulador de movimientos ya tengo la Velleman k8055N y la Saberttoh 2x12 estoy en la parte de configuracion de los axiales, hasta ahora no he podido acer andar con ningun juego espero obtener ayuda
