X-Motor Racing
Discussion in 'Off Topic - All other stuff here' started by Skaut69, Sep 4, 2010.
  1. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Did anybody play this one ?
    X-Motor Racing is an Indie racing simulator with accurate physics simulation.
    X-Motor Racing offers an unique experience which hasn't similar experiences in the market. Customizable racing simulation. All is customizable because it's possible to modify all the car specifications, including the physics. This can be useful for many things. It can be useful for adapting a car to the real model car and to make it to behave as the real one, modifying the tyres physics to behave as slicks, to make the grip different depending on the temperatures, etc.
    Main site:
    http://www.xmotorracing.com/game.html
  2. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    you can download the lattest version demo here:
    http://www.xmotorracing.com/download.html
    I tried an older demo a few months ago and did not like it very much... maybe this release is better... Good thing is that they constantly update the sim.
    Bleco
  3. JimmyPaul
    JimmyPaul New Member
    0Coins
    Thanks for sharing.Recent times Cheap Nike Free Run 2 is very popular and hot.I think you'd better have a look no matter you will buy or not.
  4. Gene
    Gene New Member
    15Coins
  5. Gene
    Gene New Member
    15Coins
    New version was released - 1.43
    Changes from 1.42 to 1.43:
    - New graphics engine
    - 100% Per-pixel lighting
    - Dynamic light sources
    - Dynamic time of day - night, sunset and day
    - Night races
    - Fog
    - Headlights, tail-light and blinkers
    - Cascaded shadow maps
    - Specular maps
    - Shadow filters
    - Adjustable alpha ref per object
    - HDR interpolation
    - Fog interpolation
    - Material interpolation
    - Light interpolation
    - Speed of time
    - Added coronas to light sources
    - Customization of shadowmap size
    - Customization of hardware PCF shadows
    - Added weather - fair/cloudly
    - Improved clutch
    - Added dead zones to the clutch
    - Improved Track IR suport
    - Added TrackIR shifts (X, Y, Z) for the cockpit camera
    - UDP socket optimization
    - Linux Servers
    - Fixed handbrake
    - Fixed Blocked differentials
    - Added exclusive DX Input mode
    - Added FFB option to multiplayer chat
    - Added Time of Day controls to server
    - Added online and offline statistics
    - HWID has been changed
  6. RaceRay
    Hamburg, Germany
    23,884Coins
    Hi Gene,
    i assume you are a developer of X-Motor Racing? Is there a free test version out?
  7. Gene
    Gene New Member
    15Coins
  8. eaorobbie
    20,503Coins
    Free download doesn't give us access to the sdk and telemetry info which would be needed to create a game plugin for the new software. Bummer.
  9. Gene
    Gene New Member
    15Coins
    Yep, the sdk is not available for the demo at the moment.
    I can only give one of the output structures that contains physics data:
  10. eaorobbie
    20,503Coins
    thankyou this now looks achievable to create a plugin, time to download demo,
    Thanks for the open info.
  11. value1
    14,240Coins
    Below you can find a SimTools plugin for X-Motor Racing. Thanks to Gene for your support!
    I'm not sure what license type you need, Demo, Standard or Pro to get motion data out of the game. Probably Gene can confirm.
    For sure you'll need SimTools for the motion. So if you are not a beta tester yet, apply for it here :)
    XMotorRacing_Plugin.zip
  12. Gene
    Gene New Member
    15Coins
    Thanks for the plugin. I hope someone will enjoy it.
    It should work in the Pro and Business versions and the Standard for 5 minutes only.
  13. Gene
    Gene New Member
    15Coins
    XMR SDK has been updated silently.
    The angles Pitch, Roll and Yaw have been fixed.
  14. Gene
    Gene New Member
    15Coins
    New version was released - 1.44
    - Graphics engine optimization
    - Improved replays
    - Improved TV replay cameras
    - Added additional reflection options
    - Improved statistics
    - Added password protection of online statistics
    - Added wheel height adjustment
    - Added Advanced SDK to the Ultimate version
    - Added double precision of simulation to the Ultimate version
    - Added auto activation
    - Added voltage, oil pressure, fuel level and engine temperature arrows to cockpits
    - Fixed blinkers
    - Added auto-sending of statistics to off-line modes
    - Fixed map rendering
    - Removed all arcade racing tracks
    - Removed three out-of-date FWD cars
    - Added BMW M3 E92 DTM
    - Added BMW M3 E92 DTM and F1 Imsa to the demo version
    - Added German and Russian localizations to the demo version
    - Minor changes in GUI
    - Added transform animation
    - Added skeletal animation
    - Added skinned mesh animation to driver
    - Added crowd simulation
    - Added animated marshals
