arduino
Discussion in 'SimTools compatible interfaces' started by hraanan, Jan 7, 2012.
  1. hraanan
    hraanan New Member
    1Coins
    I have problems with how to define the arduino in x sim. I can't see the com of the arduino in the list!!
    if anyone can help I will be very happy.
    tnx
    hraanan
  2. bsft
    Hello, there are people sorting the code so you may have to just wait like everyone else at this stage.
    :cheers:
  3. johnr
    johnr New Member
    0Coins
    Make sure you can use the Arduino outside of X-Sim first. The serial port you use outside X-Sim will be the one you select in Profiler (serial interface screen).
  4. stowaway
    stowaway New Member
    Gold Coast - Australia
    1Coins
    I'm currently trying to design an interface with the Arduino Uno.
    I'm not using the Arduino IDE Though, Im just coding directly too the Chip with WinAVR.
    Mine controls 3 motors, and at the moment just communicates through the USO. I'd be happy to colaborate. As soon as my source is sorted ill be uploading it here.
  5. stowaway
    stowaway New Member
    1Coins
    This is my code so far for the Arduino UNO. (Or just a ATMEGA328P)
    It uses PID.C/PID.H downloded from Amtel Webpage and a LCD Library.
    At the moment it reads Serial data from USO when used R~a01~~a02~~a03~E
    and saves that data to MotorX.DesiredValue
    every 10ms it calculates the PWMSpeed using pid_controller.
    and it also opens 3 PINS to use Phase Corrected PWM.
    (there is quiet a few lines in there desiged for my testing purposes)
    Ive got my H-Bridge and Winch Motor on order.. So currently it i untested in real world:
    Code:
    /*** TMC - Tippett Motion Control
    **** Timer 0B - PMW Motor 1
    **** Timer 1 - PID Timer Run PID Calculations every PIDDELAY (Currently 2500 for every 10ms)
    **** TO control Motors change OCR2B, OCR0B, OCR0A
    #include <avr/io.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <util/delay.h>
    #include <avr/interrupt.h>
    #include pid.h
    #include lcd.h
    #include <string.h>
    #define NO_OF_POTS 3
    #define NO_OF_AXIS 3
    #define NO_OF_INPUTS (NO_OF_AXIS * 2)
    #define potSensitivity 10
    /* UART SERIAL DEFINES */
    #define F_CPU 16000000UL
    #define BAUD 9600
    #define MYUBRR F_CPU/16/BAUD-1
    #define PIDDELAY 2500
    //Put in header file
    void InitPIDTimer(void);
    void ADC_Init(int preScaler, int tenBit);
    //To Do. make these values editable via lcd and buttons
    double K_P = 3;
    double K_I = 35;
    double K_D = 10;
    //TO DO. DELETE THESE VARIABLES
    volatile int desiredPosition;
    volatile int actualPosition;
    volatile uint8_t inputBuffer[NO_OF_INPUTS];
    volatile uint8_t position;
    struct Motors
    	uint16_t CurrentPosition;
    	uint16_t DesiredPosition;
    	struct PID_DATA PidData;
    	uint16_t PWMspeed;
    } Motor1, Motor2, Motor3;
    /* ADC METHODS */
    // Initate ADC.
    // Input prescaler amount, and 10bit or 8bit results
    	ADCSRA |= (1 << ADEN);  //Enable ADC
    	//To Do. Set Different prescalers.
    	if (preScaler == 128)
    		ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);  //set prescaler to 128
    	if (!tenBit)
    		ADMUX |= (1 << ADLAR);  //Left adjust ADC result to allow easy 8 bit reading
    	ADMUX |= (1 << REFS0);  //USE AVCC as refernece;
    	ADCSRA |= (1 << ADSC);  //start first conversion
    /* PWM Methods */
    void PWM_init(void)
    	/* Init Timer 0A PORT D6 or PORT 6 on Arduino */
        DDRD |= (1 << DDD6);
        // PD6 is now an output
        OCR0A = 100;
        // set PWM for 50% duty cycle
        TCCR0A |= (1 << COM0A1);
        // set none-inverting mode
        TCCR0A |= (1 << WGM00);  //PWM Phase Corrected
        TCCR0B |= (1 << CS00);
        // set prescaler to 8 and starts PWM
    	/* Init Timer 0B PORT D5 or PORT 5 on Arduino */
    	DDRD |= (1 << DDD5);
    	OCR0B = 128; // set PWM for 50% duty cycle
    	TCCR0A |= (1 << COM0B1);
    	OCR0B = 128;
    	/* INIT Timer 2B Port D3 or 3 oon Arduino*/
    	DDRD |= (1 << DDD3);
        OCR2B = 150;
        TCCR2A |= (1 << COM2B1) | (1 << WGM20);
        // set none-inverting mode & set PWM Phase correct Mode
        TCCR2B |= (1 << CS21);
    /* SERIAL METHODS */
    /* SETUP UART */
    void USART_Init( unsigned int ubrr)
       /*Set baud rate */
       UBRR0H = (unsigned char)(ubrr>>8);
       UBRR0L = (unsigned char)ubrr;
      /*Enable receiver and transmitter */
       UCSR0B = (1<<RXEN0)|(1<<TXEN0);
       /* Set frame format: 8data, 1stop bit */
       UCSR0C = (3<<UCSZ00);
          /*Turn on Receive Complete Interrupt*/
       UCSR0B |= (1 << RXCIE0);
       position = -1;
    void InitPIDTimer()
    	TCCR1B |= (1 << WGM12); // Configure timer 1 for CTC mode
    	TIMSK1 |= (1 << OCIE1A); // Enable CTC interrupt
    	TCCR1B |= ((1 << CS10) | (1 << CS11)); // Start timer at Fcpu/64
    	OCR1A   = PIDDELAY;
    void Init(void)
    	//Setup PID structs
    	pid_Init(K_P, K_I, K_D, &Motor1.PidData);
    	pid_Init(K_P, K_I, K_D, &Motor2.PidData);
    	pid_Init(K_P, K_I, K_D, &Motor3.PidData);
    	/* Init LCD */
    	lcd_init(LCD_DISP_ON);
    	/* Setup  ADC */
    	//ADC_Init(128, 1);
    	/*Turn on ADC Interrupt */
    	ADCSRA |= (1 << ADIE);
    	//Turn on PORTB 12 to input
    	DDRB &= ~(1 << PINB4);   //set input direction
    	lcd_clrscr();
    	lcd_puts(Init Okay);
    int main(void)
    	PWM_init();
    	Init();
    	InitPIDTimer();
    	/* INITALISE SERIAL */
    	USART_Init(MYUBRR);
    	//turn on interrupts
    	sei();
    	int LCDCount = 0;
    	while (1)
    		if (LCDCount > 10000)
    			LCDCount = 0;
    			char Motor1String[7];
    			char Motor2String[7];
    			sprintf(Motor1String,%u , Motor1.DesiredPosition);
    			itoa(Motor1.PWMspeed, Motor2String, 10);
    			lcd_clrscr();     /* clear the screen*/
    			lcd_puts(Motor1String);
    			lcd_gotoxy(0,1);
    			lcd_puts(Motor2String);
    			Motor1.CurrentPosition += Motor1.PWMspeed;
    			Motor3.CurrentPosition += Motor3.PWMspeed;
    		LCDCount++;
    /* INTERRUPTS */
    //Timer 1A Interrupt
    /*Every 10ms Calcualte the PWM value via pid_controller in pid.c*/
    ISR(TIMER1_COMPA_vect)
    			Motor1.PWMspeed = pid_Controller(Motor1.DesiredPosition, Motor1.CurrentPosition, &Motor1.PidData);
    			Motor2.PWMspeed = pid_Controller(Motor2.DesiredPosition, Motor2.CurrentPosition, &Motor2.PidData);
    			Motor3.PWMspeed = pid_Controller(Motor3.DesiredPosition, Motor3.CurrentPosition, &Motor3.PidData);
    //SERIAL INTERRUPT
    ISR (USART_RX_vect)
    	int input = UDR0;
    	if (input == 'R')
    		position = 0;
    	else if ((input != 'E') && (position > -1))
    		if (position < NO_OF_INPUTS)
    			inputBuffer[position] = input;
    			position++;
    		else
    			//error; ignore and restart
    			position = -1;
    	else if (input == 'E')
    		if (position == 5)
    			/* Correct Packet Count Recevied. Commit Values */
    			Motor1.DesiredPosition = (inputBuffer[0] << 8) | inputBuffer[1];
    			Motor2.DesiredPosition = (inputBuffer[2] << 8) | inputBuffer[3];
    			Motor3.DesiredPosition = (inputBuffer[4] << 8) | inputBuffer[5];
    		position = -1;
    //ADC INTERRUPT
    ISR(ADC_vect)
    	switch (ADMUX)
    		case 0x40:
    		if ((Motor1.DesiredPosition > ADC + potSensitivity) || (Motor1.DesiredPosition < ADC - potSensitivity))
    			Motor1.DesiredPosition = ADC;
    		ADMUX = 0x41;
    		break;
    		case 0x41:
    		if ((Motor2.DesiredPosition > ADC + potSensitivity) || (Motor2.DesiredPosition < ADC - potSensitivity))
    			Motor2.DesiredPosition = ADC;
    		ADMUX = 0x42;
    		break;
    		case 0x42:
    		if ((Motor3.DesiredPosition > ADC + potSensitivity) || (Motor3.DesiredPosition < ADC - potSensitivity))
    			Motor3.DesiredPosition = ADC;
    		ADMUX = 0x40;
    		break;
    	ADCSRA |= (1 << ADSC);  //next conversion
  6. MSK
    MSK Member
    53Coins
    When I checked my device manager in my control panel, beside the Arduino it was stated COM7. So, In the profiler, I typed in COM7.
    I am using 6 linear actuators (hydraulic). So using 6 axis . Is it possible for me to send data to arduino for each axis in the order I want from X-sim and then program the arduino to receive it in that format ?
    thanks
  7. stowaway
    stowaway New Member
    1Coins
    Yes, this is done in the USO. It wont show the comport in the USO but if you read the fine print under there you just need to enter a comport like //.//COM7 (from memory, it may not be exactly that, just read the text to get the format) Arduino comports WONT show up in the drop down box, but you just type in it..
    Then You just decide what format you want to send it in (i think you may need to send it as Decimal if you want to use the Arduino Librarys.. But I send it as Binary) then just set up the format you want to send it ~a01~~a02~~a03~~a04~~a05~~a06~ will just send all axis one after another, no checksum, you need to decide whats best for you, weather you want a check sum or a start character and end character or whatever.
    then you just setup the arduino to listen to the serial. easy pezy.
