can a 230mm/sec actuator be fast enough for simulators?
Discussion in 'SimTools compatible interfaces' started by simuman, Dec 28, 2011.
  1. simuman
    simuman New Member
    0Coins
    Hi Guys,
    i found this video on youtube (he is claiming a speed of only 50mm/sec)
    http://www.youtube.com/watch?v=ZzNXpGW9 ... re=related
    It looks to be fairly fast and comparable to some wiper motor setups i see here.
    My question is: Will 230mm/sec suffice? I might have found a good one for a fair price going at around that speed.
    Simu
  2. bsft
    most wiper motors will susally run about 50-80mm per second depending on load against the motor, so anything about 100mm per second, you would be on a roll.
  3. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi
    i drive with scn6 200mm/sec and its works fine.the ask is how many speed hi make under load.a scn5 make with 0 load 400mm with 1,5 kg load hi make only 200mm
    and with 7kg only 50mm.the scn6 make with 0-5kg 200mm.how many load can move
    the accuator were you have find?
  4. simuman
    simuman New Member
    0Coins
    thanks Nima,
    i'll have to get more info on them.
    Ive seen your videos on youtube. They do indeed look good enough. Although they appear to have more than 2 actuators running them. How many actuators are you using?
    particulalry this one: http://www.youtube.com/watch?v=IccaTPQm ... EM2-Cl-Rcm is this running at 200mm/sec max speed?
  5. bsft
    There probably would not be a motor available that acts like an actuator. They are two completely different operating devices.
  6. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    this video is with 4 scn5 400 mm/s
  7. simuman
    simuman New Member
    0Coins
    Ah yes that makes sense. Do you have a video of the one running at max 200mm/sec?
  8. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    no not in the moment
