rFactor Profil SimforceGT mit wipermotoren
Discussion in 'X-Sim² profiles' started by ElektronikJack, Dec 30, 2007.
  1. ElektronikJack
    ElektronikJack Member
    Techniker Elektronik
    Germany Itzehoe
    - 40Coins
    DC motor
    I use this profiles with SimforceGT Simulator with wiper motors:
    elektronikjacks-simulator-t717.html
    Profiler:
    G-Effekt 24
    G-Effekt26
    G-Effekt27 (Rumble ..curbs..)
    USO Config:
    have fun
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Hey Dirk,
    Bzw, eine Profiler savedatei für RFactor wäre noch besser (also die .rnr Datei).
    Gruss
    Christian
  3. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    where can I find motion profiles for simforce + wipermotors? regards!
  4. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi you can load a scn5 profil with only math dialog.than you must set the axis in uso
  5. rafael_design
    Brasil
    328Coins
    Hi Nima! Thanks!
    But I could not have success.
    When I open a SCN5 profile it have two actuators.
    I dont know how to transform the left/right actuators to x/y axis, that work for me.
    I understand that you said to configure USO, but how?
    I tried for several hours to figure it out without success.
    If someone could post one simple example would be awesome!
    regards!
  6. rafael_design
    Brasil
    328Coins
    Here is the profile that work for me:
    RafBRprofile2 ok.rn2
    Can you edit the USO configuration and send it back to me?
    :cheers:
  7. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi
    i dont now were i can change it in the uso but i have translate a rfactor profil from my to x any y axis
    is with slider the slider on the top are for left right effects the other for for and behind.
  8. rafael_design
    Brasil
    328Coins
    Thanks!
    Is this profile based on SCN5? Or it is for wipermotor from scratch?
    I ask because you said that we can use SCN5 profiles and I am curious about that. Some of the SCN5 profiles i've seen seem so complex, it must worth the try!
    here the video of my Sim so far:
    http://www.youtube.com/watch?v=kqpKtW_46mw
    In this video I just use 4 forces:
    accelerate/brake, side forces, vertical and gear change.
    regards!
  9. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi
    the profil is make on scn6 i have set the y value on the x axis to zero and delite the slider.
    the same with the x values on y axis.
  10. bsft
    The motion looks good, perhaps on the body roll - lateral force effect, you could try increasing this number to give you more gradual roll, so when you turn a bit the frame rolls a bit. Like when you go around a long sweeping bend, you are not turning that hard but still want a bit of car body roll. Just a though.
