Tronic's AMC motor motion-controller with pwm/servo output
Discussion in 'SimTools compatible interfaces' started by tronicgr, Aug 30, 2007.
  1. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    I have just finished Thanos electronics, and have a problem with H bridge while testing it. It works well with little electric motors on 5V and 12V, but with stronger wiper motors it doesn't work. What should be the problem?
  2. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    PSU should be 20A above..
  3. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    I have connected both wiper motors with two chieftec 300W computer PSU directly without electronics and they were working well. Each PSU gives 15A on 12V. But when I connected them through H bridge motors didn't move at all.
  4. tronicgr
    tronicgr
    You need a big capacitor or battery in parallel for the PSU to hold the load and avoid the safety circuits kick in.
  5. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    Thanks Thanos! I used two 100uF / 63v capacitors. Which bigger capacitors do you suggest for replace them?
  6. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    100uf not big enough...try bigger..
  7. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    Hi again!
    I am not having success in the test with potentiometers.
    Without potentiometer I think it acts as it should, but with the potentiometer it has a very strange behavior.
    The motor 2 with potentiometer runs full speed only one direction . :?
    http://www.youtube.com/watch?v=rfI1n4WHAVA
    The motor 1 stops with potentiometer. :thbd:
    http://www.youtube.com/watch?v=u379LJa_r8c
    Here is the test showing successful programming to Thanos firmware!
    http://www.youtube.com/watch?v=vlpY8tpV ... re=related
    Please I would apreciate any help!
    regards,
    RafBR.
  8. rafael_design
    Brasil
    328Coins
    :hi:
    Here a few hi-res pics to show:
    :sos:
  9. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    I've found the problem. H-bridge board doesn't give ground to the motors. I have to bypass it with the wire?
  10. rafael_design
    Brasil
    328Coins
    In this picture from the DSMhb_1_2b_solder_guide i got confused when Tronic say to not let each other contact but the image shows iron bolts conecting the mosfets.
    The bolt is contacting the mosfets, right?
    :blush:
    regards!
  11. fireslayer26
    fireslayer26 New Member
    45Coins
    Hey Tronic(Thanos)- I've been a fan of your motion sim since I first saw the videos of it a few years ago. I'd definitely be interested in purchasing one of your setups when they are completed. Great work!
  12. rafael_design
    Brasil
    328Coins
    I found the answer on the Tronic's DIY dual Mosfet H-bridge topic.
    Sorry for I posted in the wrong topic.
    regards!
  13. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    I am not sure if am I on the right topic. I need help! I 'm trying to test AMC and H-bridge in X-sim for the first time. I have effect 25,26,27 in my game profile. When I move slider to left and right of calibration offset of axis motors are moving well(both axis are working good), but when I start the game nothing happens, and wiper motors doesn't move at all. Why? When I move sliders of effects in test plugin in force-sender, values are changing in force-profiler as well, but motors doesn't move.
  14. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    I've had similar problem, I needed to change the crystal to 18MHz, and it started to work, but I was using generic LFS profile from Thanos (i think it's for JoyRider setup).
  15. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    Hi Igor
    I'm using 18MHz Crystal and firmware for 18MHz. Maybe the problem is in X-sim configuration. It seems like it doesn't get forces data from games. I 'm still beginner in X-sim and don't understand.
  16. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    I have installed game plugins(LFS, rFactor, GTR2) properly. As you can see in video values in force profiler are changing while playing game, but motors are not moving, and in the plugin test as well. In the calibration offset of axis motors are moving. So problem is in the AMC for sure. Did anybody have the same problem? Please help!
    http://www.youtube.com/watch?v=xf_nMiMk4Kw
  17. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    Hi Sirnoname
    a.) I saw that blue line is not moving, but I don't know why?
    b.) Here is photos of USO setup:
  18. gzezelj
    gzezelj Member
    Sombor, Serbia
    - 84Coins
    Thank you Sirnoname
    I made my own profile with 25,26,27,30 effects, and now it works great, except 27(Acceleration & Braking), both motors should work simultaneously, but one is inverted.
    Regards
  19. fireslayer26
    45Coins
    Tronic,
    Any update on your new boards?
    Thanks!
  20. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    I encountered the same problem, no answer.
    Forgive my English
    ip will As should be
