2DOF Wiper Sim from Serbia
Discussion in 'DIY Motion Simulator Projects' started by fermevc, Nov 19, 2010.
  1. Frakk
    Frakk Active Member
    328Coins
    I don't know whats wrong with it. Try to get an oscilloscope, trace down the data and see where it doesn't go through.
    Alternatively you can try this USB adapter and connect it straight to the AVR:
    http://cgi.ebay.ca/PC-USB-RS232-Module- ... 3f04f07f5f
    If you listened to me in the beginning and get a Pololu controller, you would have a moving simulator by now... :mug1:
    I will have to ask you to post your own problems in your own thread instead of hijacking Igor's.
    Thank you!
  2. Deleted member 4120
    Deleted member 4120
  3. Deleted member 4120
    Deleted member 4120
    sorry that I have made my question!
  4. fermevc
    fermevc Member
    Networking and telecomunication
    Serbia
    5,956Coins
    I dont't mind about hijacking :)
    I don't have any fresh news about mine , but I've looked at interview's photos, and I can see that MAX232 IS WRONGLY INSERTED!!!!!
    No wonder you cant communicate via x-sim com port :)
    And it is really good idea to post in your own thread about your progress and problems :yes:
  5. Deleted member 4120
    Deleted member 4120
    :) i LOVE you!!!!!!
    now work my smal LED!!! THX
    but how i connect right whit x-sim now???
    BIG THX
  6. Frakk
    Frakk Active Member
    328Coins
    Good job Igor. :D :D :D
    I assumed placing an IC in the circuit the correct way cannot be that challenging! :)
  7. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    just like me..haha
  8. fermevc
    fermevc Member
    Serbia
    5,956Coins
    Finally, I'm happy to report some progres :)
    I've found two working BOSCH wiper motors at some junkyard. I think they're from Ford Sierra. Found some reference on internet and it should be 12v 40W. I measured the current (no load) in both directions on fast speed, and it is around 2.3 Amps. I've found that the motors turn almost at the same speed in both direction (no need to do Thanos's speed hack :) ).
    Anyway, I'v made a little video showing initial testing of H-bridge. The video shows only one motor, because if I connect both motors to my AT PSU, AMC wont start at all.
    Maybe PSU hasn't enough juice or common ground turn some protection in PSU :blush:
    Both sides working at first try (tested one by one) :yippiee: :yippiee: :yippiee:
    http://www.youtube.com/watch?v=dgdjtC7-Efk
    Next thing to do is figure the way of mounting pots, and get onto welding, grinding, drilling, sandblasting, ..... my frame again :)
    In the mean time, I'll search for U-joint and rod-ends or ball-joints.
    BR, Igor
  9. fermevc
    fermevc Member
    Serbia
    5,956Coins
    I've found the way to connect the pots with motor shaft :)
    I think this setup will last, because previously I've used some hot glue to make a connection, and during first test, connection come loose, and motor shaft slammed into bracket holding the pot :(
    I've quickly jumped to turn off the power, and checked the mosfets touching the heat sinks.
    One of them got so warm, and I'v said to my self - this one is dead 100% :blush:
    Few days later, I've made proper connection, and did some tests, and everything is working OK :clap:
    I'm using some generic LFS profile found in profile directory (installed during x-sim setup).
    Anyway, I've noticed that my motors are moving separately, like in JoyRider, and I have turned on the SFGT dip switch on AMC.
    I've searched for profiles all over the place, but no luck.
    I will eventually get into making my own profile, but it would be much easier if someone could share a basic LFS SimforceGT profile.
  10. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    good job 8)
  11. fermevc
    fermevc Member
    Serbia
    5,956Coins
    It's been a long time since I've posted about my progress.
    Unfortunately, there's none (progress) :(
    But I've stumbled on something interesting for all to see (if it's not already been shown on the forum)
    Enjoy, I certainly would love to have something like this at my home :)
    http://www.cyberneum.de/f1/
  12. fredspeed
    fredspeed New Member
    Northern Norway
    418Coins
    To bad you have no progress. I guess making the electronic interface work is stopping you? In that case you are not alone! Thanks for the video, now I know what to put in the old barn!!!
  13. fermevc
    fermevc Member
    Serbia
    5,956Coins
    @fred
    Your guess is wrong :)
    My electronics are finished and working OK for a long time.
    My problem is lack of time and bad weather (it's too cold in my garage to work on welding and rearrange my existing race frame).
    I was planning to make a small test rig, but can't find the proper way of connecting motor shafts and I didn't find the U-joint either.
    On the other hand, I have trouble with profile, and can't figure out how to make my own for LFS. The generic profile I've tried is working but joy rider style.
    Even if I've made dip-switch to SFGT, I can't get the motors to work like it should.
    To bad that people from the forum don't play LFS more :(
    There were a couple requests for LFS WW profiles, but nobody answered. I don't understand why, cause I've seen a lot video clips of people driving LFS.
    Please share, share, share :)
  14. Frakk
    Frakk Active Member
    328Coins
    fermevc: It wouldn't make much sense to use other's profiles because their geometry will be different anyways. You are much better off making your own profiles and not depend on others (which would not work good anyways). You might need a bit of time to get the hang of it, but if you start piece-by-piece, effect-by-effect, making profiles is really not complicated. The hardest part is finding the sweet spot that you like the most.
  15. fredspeed
    Northern Norway
    418Coins
    Lucky you, good to here this is working for some!!! :thbup:
  16. fermevc
    fermevc Member
    Serbia
    5,956Coins
    @frakk
    I understand your point of view, and I'll give my best :)
    I'll stop wining and get into reading the basics (if only search would work, it would be much easyer)
