Problem with wipers motor help!
Discussion in 'SimTools compatible interfaces' started by theboemio, Oct 6, 2010.
  1. theboemio
    theboemio New Member
    1Coins
    hello good day!
    I use a servo controller connected to the serial port (http://www.pololu.com/catalog/product/727), a motor controller (http://www.pololu.com/catalog/product/707) and servo motors to control the motor position of the wipers, but hits harder when going up than down ...
    any idea how to be the same speed both ways?
    Try moving the magnetic field of the motor but moves the position of the screws and I have no cast-steel welding.
    anyone can tell me the difference between: a servo-motor-digital and analog servo motor?
    but I have other servo motors, are analog and do not work with the servo controller.
    Greetings and thank you very much!
  2. Frakk
    Frakk Active Member
    328Coins
    What are you trying to do?
    You know that those two boards don't work with each other right?
  3. theboemio
    1Coins
    Hello
    And I have movement in my Sim, the problem is going faster down one side than the other.
    My question is: there will be some way to make these motors turn at the same speed in both directions?
    I've Intended to move the magnetic housing but do not know how to weld cast steel.
  4. Frakk
    Frakk Active Member
    328Coins
    First make sure it is the motor. Run it in both directions with only the power supply.
    It would help if you posted pictures of your hardware, right now we don't have any information to help you.
    Just go in the Upload attachment tab when you post a reply.
  5. theboemio
    1Coins
    Definitely is the motor, I've tried only the 12v power source.
    This is my hardware when I have the camera again to take more pictures here to share more information.
    gallery/image.php?album_id=54&image_id=298
    gallery/image.php?album_id=54&image_id=297
    gallery/image.php?album_id=85&image_id=300
    gallery/image.php?album_id=85&image_id=299
    I have a couple of motors to raise the mirror of the door and turn the same in both directions, the problem with these is that they have the arm and not as soldiers one, try a welder but it melted the steel.
  6. Frakk
    Frakk Active Member
    328Coins
    Your first 2 pictures don't have a link, cannot see your motors.
    Just attach it simply in the post.
  7. theboemio
    1Coins
    I went with my 12v battery and my bridge h for a new engine wipers and found that almost equal to two-way turn ... buy them and work great!
    the difference is 3 revolutions per minute and the simulator is going well!
    I have some problems with the servo controller, to start the Profile flashes red and I have to turn off and on again to start sending data from the Profile
    Any ideas on this error servo controller?
    thanks for answering greetings!
