F1 2010 - output data to multiple devices?
Discussion in 'Archived information' started by ledfoot, Sep 25, 2010.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Strange.
    Dirt2 and F1 2010 have the same output mechanism, and EK had a working mechanism to extract data from Dirt2 and that mechanism worked along side X-Sim.
    One has to wonder why he wouldn't use that same already working code instead of writting new code, and asking X-Sim users that have an SLI to get the data from his program rather than directly from the game. Why re-do the work and why do it in such a manner that it makes it more difficult for X-Sim users?
    Am I missing something? I can do some testing as well in a few days.
  2. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I'm not really sure why he would do that either Berney. His proxy for DIRT 2 and F1 2010 is independent from the SLI Manager so you would not need to have an SLI to use it but it does not yet work with X-Sim.
    @Martin,
    I tested your latest Outsim plugin and it works perfectly with both DIRT 2 and F1 2010. I changed DIRT 2 and F1 config files to use port 20778 as instructed and the SLI Manager uses it's default port of 20777 now I can run both games with the SLI-Pro and X-Sim at the same time without any loss of motion quality.
    Note.... You will need the latest beta SLI Manager 094d18c in order for the SLI-Pro or M to work with F1 2010.
    Thanks Martin for sorting this out.
    ....Mike
  3. bvillersjr
    Ohio, USA
    438Coins
    So this is now working without the need for a 3rd party proxy? I hope so.
    It would seem unfortunate for SLI owners to wind up with reduced motion quality (vs a standarard X-Sim solution) as the result of an unneeded proxy. We should only use proxies when there is absolutely no other choice!
  4. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Yes, it is working without the need for a proxy.
    ....Mike
  5. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Thanks Martin!
    Great job!
    Mike, ask EK why he decided to change what was working properly before (Dirt2)...
    Cheers,
    MY
  6. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I asked him but he didn't really answer the question.
  7. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thanks Martin,
    I'll do some testing with this tonight and let you know.
    ....Mike
  8. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Martin,
    I finally got a chance to test the latest plugin and there are some issues with it.
    1) It does work with the default settings of 127.0.0.1 port 20777
    2) It passes through the data to the SLI Manager running on port 20778
    3) The autostart feature does not work. I cleaned the registry of sender values and also made sure that autoscan was enabled
    4) I do not use FSD's so I could not test this
    5) Not sure what you mean by this one but I did not get any errors when closing the sender or plugin if that is what you are asking.
    The main issue that I am seeing is that the profiler will stop at very brief intervals like I'm missing some data. This seems to be more noticeable when running in DX11 mode with F1 2010 but it also occurs with DX9. I removed this plugin and went back to the last one that you sent that is configured to listen on port 20778 and allow output to 20777 and it works without any issues in both DX9 and DX11.
    I have not tested the new plugin with DIRT 2 only F1 2010.
    ....Mike
  9. bvillersjr
    Ohio, USA
    438Coins
    For testing #4, you can use the Commander.
  10. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Working on them now Martin. I need to verify that they will autostart when F1 is started. Will get back to you shortly.
  11. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Hi Martin,
    Here are some screenshots of the tasks and processes running while F1 2010 is running. Is autostart supposed to work with the old DIRT 2 plugin by adding these settings for F1 2010? If so, it does not work.
    ....Mike
  12. bvillersjr
    Ohio, USA
    438Coins
    Just tested this. I have the correct entries in the Autostart entries, but the sender does not automatically change to the correct plugin when I start the game.
    Window Name = F1 2010
    EXE = f1_2010_game.exe
      20.7 KB
      677
  13. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thanks Martin,
    I'll test this shortly.
  14. bvillersjr
    Ohio, USA
    438Coins
    The capital F was the problem. Auto-Detection works here now. I did not drive it though.
  15. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I just drove it briefly and it is working much better than the previous version and auto-detection is working fine for me as well after the change to the large F :).
    The data passtrhough to the SLI Manager is also working fine.
    Will test further later tonight.
  16. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    1) Tested OK
    2) Tested OK
    3) Tested OK
    4) Tested OK
    5) Tested OK
    6) Tested OK, no more micro breaks
    Tested with DIRT 2 and F1 2010
    ....Mike
  17. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    Hi Guys,
    I am having problems with this... I read the thread but cannot come up with a solution.
    Problem is that both the motion and the Sli-pro work together, but the motion is not as good as it should be, or used to be, kinda jerky.
    My system cannot be a problem because i upgraded my pc some weeks ago with a i7 - SSD - 6gbRam - W7 64bit, and now using my old pc for the profiler. (E6600 2.4 core2duo - 2gbRam - XP)
    I used the latest multicast plugin and used 20778 in the hardwareconfig. Also cleaned the registry.
    Am i missing something here?
    Thanks in advance.
    Rob
  18. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    The plugin is working fine for me running on an i7 950 @ 4.1GHZ Windows 7-64 bit. I have the profiler and sender running on the same PC.
    SLI Pro also works fine.
    ....Mike
  19. splendiddd
    CCTV security
    Netherlands
    812Coins
    Solved, after a new W7 install (my ssd failed grrr) it worked properly, so i do not know what the problem was.
    After the F1 game update, native support is enabled. You can also use the Slipro app but you need to add a line in the hardware_config file to disable native support.
    qoute EK:
    ok change or add this line in ..\My Game\FormulaOne\hardwaresettings\hardware_settings_config.xml:
    <led_display nativeSupport=true brightness=127 />
    to
    <led_display nativeSupport=false brightness=127 />
    Sadly F1 2010 does not have sector times or other functions on the SLi, so i just use the native support from cm.
  20. CXCSimulations
    CXCSimulations Member
    - 9Coins
    I have gotten the native system to work just fine, but the brightness is extremely low. I tried inserting the above mentioned <led_display nativeSupport=true brightness=127 /> into the hardware_config file, but it ignores and erases it as soon as the game starts.
    Any ideas?
