Playseat Revolution to 2DOF
Discussion in 'DIY Motion Simulator Projects' started by dr.feelgood, Apr 19, 2017.
  1. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    484Coins
    Hi!
    Finally decided to try Traction Loss. Because i'm not sure weather to be able to keep it, i made just a try-out kit.
    3 ball bearings to back, to front one bearing...one like from shopping cart. One motor bolted to the back of frame and just T-shape flat metal 'gutter'? i had for years. One more arduino with IBT-2 and no welding to frame at all.
    For stability i added 2 more small 40mm wheels bolted to the front corners of frame. Frame is just lifted over this set.
    Pictures...
    Have been testing a lot and it seems that i have a bit too little side-to-do-side movement. It is not always so clear when back breaks out. Sometimes i notice it only after when slide stops and comes back to normal. Still tuning....
    I also made adjustable shift-light by eaorobbie, will get back to that later (had to purchase pro license for Dash).
  2. dr.feelgood
    FINLAND
    484Coins
    Hi!
    I made custom brackets for motor fans. Getting hang on 3D-printing :)
  3. dr.feelgood
    FINLAND
    484Coins
    Hi all!
    Traction loss was in use for some time and now it is gone... I broke two old wipermotors with it. Somehow i did not get it tuned so that it would not hit physical limits and finally gears broke down.
    Oh well, it was for test anyhow. Best result/feeling i got with it, was to disable sway, so it would not mix my head ;)
    :oops: End of summer and end of fun... I have changed this to seat-shaker only and moved it in-da-house...
    First impression was a big disappointment, but after little tuning and trying out some race tracks, i hope it will satisfy my needs over winter... Rallying is not the same, thou.
  4. dr.feelgood
    FINLAND
    484Coins
    Hi! Here are some pictures my current setup. So it's seat mover only and i modified it by fixing pedal-support to base and before that i turned whole thing 180 degrees. That i did partly for safety reasons.
    seatmover11 (1280 x 1145).jpg seatmover12 (1280 x 1028).jpg seatmover13 (1280 x 855).jpg
    And here are couple of racing videos...
  5. Gadget999
    12,331Coins
    do you need to keep the ibt-2 cool with any fans ?
    how many watts / amps / N are your motors ?
  6. dr.feelgood
    FINLAND
    484Coins
    Hi @Gadget999 !
    I have boxed both IBT's in the same box with Ard Uno. 80mm fan on other end of box blows air thru them -> no heat problems. My motors draw only few amps, ~40w or so, i have not found specific data anywhere. I use 10 Amp fuse on each motor, as you can see them on power source. Motors themselves do get hot and i use other 80mm fans over them. Hope this helps!
  7. Gadget999
    12,331Coins
    thanks for the feedback - my motors don't seem to get hot at all, the ibt-2 do seem to get hot but its under control with the fans :)
  8. dr.feelgood
    FINLAND
    484Coins
    Hi all!
    I little video about noise that my rig makes.... I try to make it more environmental friendly :)
  9. dr.feelgood
    FINLAND
    484Coins
    Hi all!
    Just wanted to update a current state of my rig. Basicly I'm still using same foundation, but with upgrades like VW Golf mk III seat, doubled IBT's and motors from Toyota Avensis electric powersteering.
    This setup has been working great for few years now. I have earlier burned couple of IBT's, but they are cheap like soap, so I got many of them as spares...
    PC server powersupply is very sensitive for back-current and it may shutdown on violent movements, but all I need to do is to switch it 'off-on' and it works fine again.
    I use seat with Moza-wheel, Simsonn-pedals, Pico VR-glasses and DIY handbrake/H-/Sequental-shifter-combo.
    Here is some 2026 up-to-date pictures and a video.
    SIMTOOLS - 2-DOF Seatmover
