A2M-80SV02430 servo and S2-SVD15 driver
Discussion in 'Motor actuators and drivers' started by sirbrialliance, Jul 18, 2025.
  1. Lubju
    Lubju New Member
    - 38Coins
    Hi @sirbrialliance
    Have you managed to get the S2-AVD driver working with Thanos, and have you fixed the EMI issue?
    I'm looking for a more affordable servo/driver combo — the AASD units are way too expensive for my budget.
    Thanks!
  2. Joe Cortexian
    1,616Coins
    I have an HTLNC drive from AliExpress, which is similar to what you're describing. I recently purchased a BigScreen Beyond 2 (BSB2) VR headset. As soon as I turned on the AC servo, the BSB2 lost synchronization, which motivated me to investigate electromagnetic interference (EMI).
    I bought a Faraday bag on Amazon and tested it. I found that placing just the motor's UVW cable inside the bag allowed the headset to work properly. After researching, I learned that AC servo cables (like the UVW) are notorious for generating noise, especially since mine was unshielded. I decided to focus on shielding that cable.
    I purchased a woven copper braid (1/2-inch diameter) from Amazon: https://a.co/d/0Iw7Rsx. It was straightforward to install—you can stretch the braid to create a wide opening and slide it over the cable. I grounded it using a couple of ground screws on the DIN rail.
    Unfortunately, even with the shielding, the BSB2 still won't sync reliably, so I'm returning it.
  3. Aerosmith
    Aerosmith Active Member
    self employed
    2,933Coins
    3DOF, AC motor
    Please forget that copper braid. It's good as ground strap for the door of a cabinet, for example, but not for shielding cables. Replace the unshielded cable. It's not too expensive, around €1/m if you buy 25m.
    You also have to install an EMI filter with a common mode choke at the AC input of the drives to block interference going into the power grid. Blaming the VR headset for the interference caused by the servo drives is no solution.
  4. zmaniac17
    zmaniac17 New Member
    25Coins
    Thanks for the info. I really need this right now. I have one working but it has to sit almost outside the room so it doesn't interfere with the arduinos. I've got ferrite cores and I'm going to get an emi filter. I hope there's a place that ships cable that cheap to the US.
    From what I've seen these motors should work just fine once the emi is dealt with.
    The whine is not a problem. I can't really hear it. I have tinnitus though so maybe I'm just mentally blocking it. It would be impossible to hear over the engine of the car.
    Other than that, no major differences from the AASD's.
    Edit: One difference PN97 motor direction operates in the opposite direction as the AASD drivers by default.
  5. Joe Cortexian
    1,616Coins
    I’m trying to keep this conversation constructive. I wasn’t suggesting the external braid as a permanent or ideal solution—only mentioning it because it had helped with several other interference issues in my setup. The VR headset was the one case where it didn’t completely solve the problem.
    I’m also still working through the practical side of making motor cables, including how to handle the connectors. I’m looking for clarity on the best way to approach that part of the job. An example of the cable is a good start.
    EDIT: That link is 3 conductors my servo has four conductors. PE is a ground conductor which is built into the connector on the motor.
  6. Aerosmith
    self employed
    2,933Coins
    3DOF, AC motor
    Sorry, I didn't meant to be offensive. At my day job I sell CNC controllers and I've seen such patchwork with aluminium foil and copper braid too often. Customers are complaining that something doesn't work and when I ask them to send a photo of their wiring I discover it's a total mess. My customers have an industrial background so they should know better. Of course, most hobbyists here don't, their budget is lower and so I should lower my expectations.
    You can use the shield as ground conductor if it has enough cross section and if the connector allows it. If not you have to use a 4-wire cable.
  7. Joe Cortexian
    1,616Coins
    I thought you might have more practical experience than most. You’re not wrong. I ordered connector pins for the amp end and I am now pretty sure the motor side is a 4 pin Molex connector. So I should be in a position to make a new cable in a few days.
  8. cfischer
    Colorado
    2,831Coins
  9. JaMo
    JaMo New Member
    Tuesday
    8Coins
    AC motor, Arduino
    Well, the manual does have 15-20 set to empty, and I wonder if it outputs encoder data, given there are 5 wires in the encoder cable, and 5 output pins in that section. Does anyone have any idea what those pins actually are? I'm trying to use this motor for a sim wheel and need encoder data out with an arduino.
  10. zmaniac17
    25Coins
    After some sluthing I found this manual on Aliexpress. I had Perplexity go through the PDF so take this info with a grain of salt, but it should get you on the right track. I also don't know for sure if there's something the manufacture had to do to enable those pins. This could be for a slightly different model or some other arcane sorcery. You'll have to test it out. I attached the PDF.
    CN2 Pin Signal Function
    20 PA (A+) Encoder A channel positive (differential)
    19 PA− (A−) Encoder A channel negative
    18 PB (B+) Encoder B channel positive (differential)
    17 PB− (B−) Encoder B channel negative
    16 PZ (Z+) Encoder Z index pulse positive
    15 PZ− (Z−) Encoder Z index pulse negative
    22 OZ Z pulse open-collector output
    1 GND Signal ground
    Function CN2 Pin Arduino Connection
    Power (12–24V) 9 External supply only
    COM / GND 10, 1 Arduino GND
    Servo Enable (SigIn1) 6 Digital out → optocoupler
    Pulse PP+ 3 Digital out (STEP) via 330Ω
    Pulse PP− 14 GND
    Direction PD+ 4 Digital out (DIR) via 330Ω
    Direction PD− 5 GND
    Servo Ready (SigOUT1) 11 Digital in + 4.7kΩ pull-up
    Position Done (SigOUT3) 12 Digital in + 4.7kΩ pull-up
    Z-pulse open collector 22 Interrupt pin + 4.7kΩ pull-up
    Encoder A+ / A− 20 / 19 Via 26LS32 → Arduino pin
    Encoder B+ / B− 18 / 17 Via 26LS32 → Arduino pin
    The differential PA/PB/PZ signals use RS-422 / 26LS31 line driver output, which means you need a 26LS32 line receiver IC to convert them to 5V logic for Arduino. Alternatively, for the OZ pin (pin 22), that's an open-collector Z-pulse you can connect directly to Arduino with a pull-up resistor.
    Simple open-collector Z-pulse (pin 22 → Arduino):
    • Connect OZ (pin 22) → Arduino interrupt pin (e.g., D2)
    • Connect a 4.7kΩ pull-up resistor from that pin to 5V
    • Connect GND (pin 1) → Arduino GND
    • VCC max is 30V, 50mA — your 5V Arduino pull-up is fine
    Full A/B/Z differential (recommended for position tracking):
    • Use a 26LS32 receiver IC (cheap, ~$1) between the PA/PA−, PB/PB−, PZ/PZ− pairs and your Arduino interrupt/digital pins
    • This gives you full quadrature position feedback at up to 550kHz
  11. JaMo
    JaMo New Member
    Tuesday
    8Coins
    AC motor, Arduino
    well, id rather use this in torque mode, and if i just use the pwm output from the arduino and use a capacitor to make it truly analog, would that work? it would make more sense for a sim wheel, right?
  12. zmaniac17
    25Coins
    I couldn't tell you, I have not looked into building a wheel. From what I understand though they need position feedback because you're turning the wheel/motor.
    As far as getting an analog signal from the Arduino, I am going to be using a nano and a DAC to convert to analog for torque mode for a belt tensioner.
    https://a.co/d/0hdORvgr
  13. JaMo
    JaMo New Member
    Tuesday
    8Coins
    AC motor, Arduino
    ah, well from my research, and logic it seems that applying a certain amount of force left or right makes more sense than telling to go to here, as it would just use all the torque it has to do that instead of applying torque until it gets to the right place. and even so, i need encoder output more than saying to go here because i would have control on the wheel and it would never reach the place it wanted. but the capacitor and resistor combo worked for me to make my pwm analog. still struggling with the encoder data though, because i dont wanna buy the ic chip, i cant find any cheap online, unless i can find it at a store but i doubt it around where i live.
