Showroom Smitty's Rotary Servo 6DOF build (Complete!)
Discussion in 'DIY Motion Simulator Projects' started by smitty, Dec 15, 2021.
  1. GettinBetter
    CAD Engineer
    Kent, UK
    721Coins
    11th motor, wow, cool.
    6 DOF.
    2 Cyclic.
    1 Collective.
    1 Anti Yaw pedals.
    1 Trim Control.
    Seat belts?
  2. smitty
    smitty Active Member
    948Coins
    nah, no desire to complicate the belts, i have a nice retracting 4-point i show in this post
  3. NicoFromHere
    NicoFromHere New Member
    28Coins
    Hi Smitty
    Firstly thank you for sharing your project with us.
    Are there any measurements on the base of the simulator which in hindsight you would do differently?
    You made a post about your simulator moving, on one of your crash videos you can see the thing significantly lifting from the floor.
    Would you suggest making the base bigger or did you just tune down the motors to avoid this phenomenon?
    Thanks!
  4. smitty
    948Coins
    The base is plenty wide and heavy enough, but i have switched from flypt to DRSM https://docs.departedreality.com/dr-sim-manager
    which has a really great crash detection, it pauses telemetry for a few seconds and then smoothly resumes after things have settled down. I don't have to wince as i'm about to hit something anymore, and the base doesn't hop around.
  5. NicoFromHere
    28Coins
    Thanks for your quick feedback!
    I'm using SimTools but I might have a look at DRSM. Looks interesting.
  6. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    236Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    Congratulations on the great work and quality
  7. 毛大大
    毛大大 New Member
    36Coins
    Hello, what are the dimensions of the hexagonal base plate?
  8. smitty
    948Coins
    760mm across flats
  9. boy
    boy New Member
    97Coins
    This is amazing! Is this project open source?
  10. smitty
    948Coins
    The joystick Y axis needed an upgrade! With the joystick extension, it just wasnt strong enough for my taste, and it kept getting pretty warm in acrobatic planes. So, i converted it to the 86BLF04 motor and 10:1 gearbox. at full power you need 2 hands to pull it back!
